メインコンテンツにスキップ
Lenovo IdeaPad Flex 4-1470 Motherboard Replacement
必要な工具と部品
  1. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Lower Case: 手順 1、 1の画像 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: 手順 2、 2の画像 1 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: 手順 2、 2の画像 2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Cooling Fan: 手順 3、 2の画像 1 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Cooling Fan: 手順 3、 2の画像 2
    • Remove the two 4 mm Phillips #0 screws which mount the fan.
  4. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: 手順 4、 3の画像 1 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: 手順 4、 3の画像 2 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: 手順 4、 3の画像 3
    この手順で使用する道具:
    購入する
    • Using the Precision Tweezers, remove the 2 gray wires around the fan from their clips.
  5. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: 手順 5、 2の画像 1 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: 手順 5、 2の画像 2
    • Use 2 plastic opening tools to remove the fans power wire from the Mother board and remove the fan.
    • Lift the cooling fan out of the laptop.
  6. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Wifi Card: 手順 6、 1の画像 1
    • Remove the foam on the WIFI card.
  7. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: 手順 7、 1の画像 1
    • Remove the wires attached to the WIFI card.
  8. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: 手順 8、 1の画像 1
    • Unscrew the 4mm screw holding wifi card.
  9. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Motherboard: 手順 9、 1の画像 1
    • Unscrew the twelve 4mm screws with a #0 Phillips screwdriver.
  10. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: 手順 10、 1の画像 1
    • Remove the motherboard.
    • The motherboard will be in place when the screw holes line up.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Elijah Ellis
メンバー登録日: 11/08/18
616 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G2, Gulbrandsen Fall 2018人のメンバー
UMASSD-GULBRANDSEN-F18S5G2
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 1,299
