メインコンテンツにスキップ
はじめに
A Wi-Fi card replacement is a quick and simple task. If you are experiencing slow or intermittent internet connection a Wi-Fi card replacement might be in order.
パーツ
パーツは指定されていません。
  1. Power off your Lenovo Ideapad Flex4-1130 before beginning disassembly.
    • Power off your Lenovo Ideapad Flex4-1130 before beginning disassembly.
    • Remove the ten 4mm screws from the back panel.
  2. Insert the spudger into the groove work your way around the laptop to separate the bottom from the case.
    • Insert the spudger into the groove work your way around the laptop to separate the bottom from the case.
    • Do not insert the spudger too deep! This could potentially damage a device part.
  3. Remove the connector attaching the battery to the motherboard.
    • Remove the connector attaching the battery to the motherboard.
  4. Remove the four 4mm screws on the battery.
    • Remove the four 4mm screws on the battery.
  5. Lift the battery with a spudger and remove.
    • Lift the battery with a spudger and remove.
  6. Remove one 5mm screw. Remove one 5mm screw.
    • Remove one 5mm screw.
  7. Remove the Wi-Fi card from the motherboard socket. Remove the Wi-Fi card from the motherboard socket.
    • Remove the Wi-Fi card from the motherboard socket.
終わりに
Adrian Miranda
メンバー登録日: 2018年02月15日
677 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team S17-G5, Boczar Spring 2018 USF Tampa, Team S17-G5, Boczar Spring 2018人のメンバー
USFT-BOCZAR-S18S17G5
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 233
