メインコンテンツにスキップ
Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement
必要な工具と部品
  1. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement, Battery: 手順 1、 1の画像 1
    • Flip laptop over so the model sticker is showing, and begin to unscrew all of the screws.
  2. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: 手順 2、 1の画像 1
    • Pop off the back panel using a plastic opening tool once all screws are removed.
  3. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: 手順 3、 1の画像 1
    • Once the panel is fully removed, begin to unscrew the battery.
  4. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: 手順 4、 2の画像 1 Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: 手順 4、 2の画像 2
    • Use the iFixit Opening tool to disconnect the battery from the circuit board.
    • When all screws are removed from the battery, carefully lift the battery up.
  5. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: 手順 5、 1の画像 1
    • The battery is completely removed, and can be replaced with a new battery.
  6. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement, Fan: 手順 6、 1の画像 1
    • Remove all screws securing the fan to the laptop.
  7. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: 手順 7、 1の画像 1
    • Unhook the wire from the fan component using a spudger.
  8. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: 手順 8、 1の画像 1
    • Now the fan is completely removed.
  9. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement, Touchpad: 手順 9、 1の画像 1
    • After battery is removed, you will move to the touchpad.
  10. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: 手順 10、 1の画像 1
    • Before removing touchpad you will have to disconnect it from the circuit board using a nylon spudger.
  11. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: 手順 11、 2の画像 1 Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: 手順 11、 2の画像 2
    • Remove all the screws holding the touchpad down.
  12. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement, Circut Board: 手順 12、 1の画像 1
    • Once fan and battery are removed, you are finally able to fully access the circuit board.
  13. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: 手順 13、 2の画像 1 Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: 手順 13、 2の画像 2
    • Disconnect the touchpad cord from the circuit board using a nylon spudger.
  14. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: 手順 14、 1の画像 1
    • Then you will lift up the flap that holds these wires down.
  15. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: 手順 15、 3の画像 1 Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: 手順 15、 3の画像 2 Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: 手順 15、 3の画像 3
    • After the flap is opened then you will have to go and remove all the screws holding the circuit board to the computer.
  16. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: 手順 16、 1の画像 1
    • After the screws are removed from the circuit board, you will have to remove these last screws to remove it completely.
  17. Lenovo IdeaPad FLEX 4-1580 Circuit Board Replacement: 手順 17、 1の画像 1
    • The circuit board is completely removed.
終わりに
作成者
2人の作成者と共同で作成されました。
Matthew Hurtt
メンバー登録日: 09/24/18
746 ポイント
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 827
