メインコンテンツにスキップ
Lenovo IdeaPad A1-07 Battery Replacement
必要な工具と部品
  1. Lenovo IdeaPad A1-07 Battery Replacement, Back Cover/Midframe: 手順 1、 3の画像 1 Lenovo IdeaPad A1-07 Battery Replacement, Back Cover/Midframe: 手順 1、 3の画像 2 Lenovo IdeaPad A1-07 Battery Replacement, Back Cover/Midframe: 手順 1、 3の画像 3
    • With the blue plastic opening tool, use the lock screen switch by the volume button as an access point to gently lift the back cover off.
    • Wedge the opening tool until you start hearing the back cover popping off the body of the device.
    • Slide the opening tool down the length of the device.
    • Once it is about half way off, you can use your thumb to pull the rest of the back cover off.
  2. Lenovo IdeaPad A1-07 Battery Replacement: 手順 2、 3の画像 1 Lenovo IdeaPad A1-07 Battery Replacement: 手順 2、 3の画像 2 Lenovo IdeaPad A1-07 Battery Replacement: 手順 2、 3の画像 3
    • Using a Phillips #000 screwdriver, remove all 18 of the 4mm screws.
    • With the blue plastic opening tool, gently wedge the tool between the screen and the gray frame until you feel resistance.
    • Do not force the frame off because you can break off the teeth securing the frame to the screen.
    • Push in the teeth with the blue plastic opening tool, towards the center of the device, and gently pull off the frame.
    • The gray frame will still be connected to the device by a pair of wires from the motherboard to the speaker.
  3. Lenovo IdeaPad A1-07 Battery Replacement: 手順 3、 2の画像 1 Lenovo IdeaPad A1-07 Battery Replacement: 手順 3、 2の画像 2
    • The speaker in the grey frame is connected to the motherboard by the white plastic connector.
    • Disconnect the speaker by separating the two sides of the speaker connector.
  4. Lenovo IdeaPad A1-07 Battery Replacement, Battery: 手順 4、 3の画像 1 Lenovo IdeaPad A1-07 Battery Replacement, Battery: 手順 4、 3の画像 2 Lenovo IdeaPad A1-07 Battery Replacement, Battery: 手順 4、 3の画像 3
    • Use a plastic opening tool to push the white battery connector out of its socket on the motherboard.
    • Lift the battery away from the device.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Madison Cranmer
メンバー登録日: 04/10/17
370 ポイント
4のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 9
今までの合計 830
