はじめに
The back cover and midframe of the Lenovo IdeaPad A1-07 may need to be replaced they are damaged with a scratch or normal wear and tear. This guide will walk you through how to carefully take the back cover and grey frame apart.
必要な工具と部品
With the blue plastic opening tool, use the lock screen switch by the volume button as an access point to gently lift the back cover off.
Wedge the opening tool until you start hearing the back cover popping off the body of the device.
Slide the opening tool down the length of the device.
Using a Phillips #000 screwdriver, remove all 18 of the 4mm screws.
With the blue plastic opening tool, gently wedge the tool between the screen and the gray frame until you feel resistance.
Push in the teeth with the blue plastic opening tool, towards the center of the device, and gently pull off the frame.
