メインコンテンツにスキップ
Lenovo IdeaPad 330S-14IKB RAM Replacement
必要な工具と部品
  1. Lenovo IdeaPad 330S-14IKB RAM Replacement, RAM: 手順 1、 1の画像 1
    • Begin by placing your laptop upside down so that you can see the labels on the back.
  2. Lenovo IdeaPad 330S-14IKB RAM Replacement: 手順 2、 2の画像 1 Lenovo IdeaPad 330S-14IKB RAM Replacement: 手順 2、 2の画像 2
    • Remove the 10 screws from the bottom of the laptop.
    • (Silver, 5.8mm Phillips #0)
    • Safely store these screws in a secure location, like a magnet pad, to prevent them from getting lost.
  3. Lenovo IdeaPad 330S-14IKB RAM Replacement: 手順 3、 1の画像 1
    • Carefully remove the back panel from the laptop.
    • Be sure to proceed slowly and use wedges to avoid damaging the panel.
  4. Lenovo IdeaPad 330S-14IKB RAM Replacement: 手順 4、 1の画像 1
    • Locate the black panel and remove these three black screws.
    • (Black, 5.83mm Phillips #0)
  5. Lenovo IdeaPad 330S-14IKB RAM Replacement: 手順 5、 2の画像 1 Lenovo IdeaPad 330S-14IKB RAM Replacement: 手順 5、 2の画像 2
    • To access your RAM, remove the black panel you just removed the screws from.
    • Remember to keep these screws separate and do not mix them with others.
  6. Lenovo IdeaPad 330S-14IKB RAM Replacement: 手順 6、 1の画像 1
    • Your RAM will be a blue rectangle, positioned almost in the center of the device.
  7. Lenovo IdeaPad 330S-14IKB RAM Replacement: 手順 7、 2の画像 1 Lenovo IdeaPad 330S-14IKB RAM Replacement: 手順 7、 2の画像 2
    • To remove your RAM, gently pull back on the metal clips holding it in place.
    • Carefully slide the RAM out of the slot.
    • Be gentle to avoid damaging the slot
  8. Lenovo IdeaPad 330S-14IKB RAM Replacement: 手順 8、 1の画像 1
    • Now, take your new RAM module and locate the notch on it.
  9. Lenovo IdeaPad 330S-14IKB RAM Replacement: 手順 9、 1の画像 1
    • Align the notch on your replacement RAM as shown in the previous step with the corresponding slot on the device's RAM slot.
  10. Lenovo IdeaPad 330S-14IKB RAM Replacement: 手順 10、 2の画像 1 Lenovo IdeaPad 330S-14IKB RAM Replacement: 手順 10、 2の画像 2
    • Gently insert the RAM module.
    • Once it's as far in as it can go, lower it slowly until the metal clips lock it into place.
    • You should hear an audible click when it's securely in place.
終わりに
To reassemble your device, follow steps 6-1 in reverse order.
3 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Luke Garrett
メンバー登録日: 09/27/23
238 ポイント
1ガイドが承認済み
チーム
Linn Benton Community College, Team 1-3, Karnes Fall 2023 Linn Benton Community College, Team 1-3, Karnes Fall 2023人のメンバー
LBCC-KARNES-F23S1G3
5 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 27
今までの合計 202
