メインコンテンツにスキップ
Lenovo IdeaPad 330S-14IKB Fan Replacement
必要な工具と部品
  1. Lenovo IdeaPad 330S-14IKB Fan Replacement, Fan: 手順 1、 1の画像 1
    • Place the laptop with its bottom facing up, so you can easily read the labels on the back.
  2. Lenovo IdeaPad 330S-14IKB Fan Replacement: 手順 2、 1の画像 1
    • Remove the 10 screws from the bottom of the laptop.
    • Keep these screws in a safe place, such as a magnetic pad, to prevent them from getting lost.
    • (Silver, 5.8mm Phillips #0)
  3. Lenovo IdeaPad 330S-14IKB Fan Replacement: 手順 3、 1の画像 1
    • Slowly and carefully remove the back panel from the laptop.
    • Use wedges if necessary to avoid damaging the panel.
  4. Lenovo IdeaPad 330S-14IKB Fan Replacement: 手順 4、 1の画像 1
    • Locate the fan in the top left corner of the laptop.
  5. Lenovo IdeaPad 330S-14IKB Fan Replacement: 手順 5、 2の画像 1 Lenovo IdeaPad 330S-14IKB Fan Replacement: 手順 5、 2の画像 2
    • Find the black panel in the top right and remove the three black screws.
    • Remove the black panel
    • Keep the black screws separate from the silver ones.
    • (Black, 5.83mm Philips #0)
  6. Lenovo IdeaPad 330S-14IKB Fan Replacement: 手順 6、 1の画像 1
    • Your fan will have one black screw connected to it on the left side. Remove this screw.
    • Keep the screw separate from the black screws in the previous step as it is a different size.
    • (Black, 3.47mm Phillips #0)
  7. Lenovo IdeaPad 330S-14IKB Fan Replacement: 手順 7、 1の画像 1
    • The fan is connected to a heat sink; leave the heat sink in place but remove the adhesive connecting the two pieces.
  8. Lenovo IdeaPad 330S-14IKB Fan Replacement: 手順 8、 2の画像 1 Lenovo IdeaPad 330S-14IKB Fan Replacement: 手順 8、 2の画像 2
    • Before removing the fan, locate a small set of yellow, red, blue, and black wires on the right side of the fan.
    • Gently remove them from the connector without pulling on the wires.
    • You can use a screwdriver or a similar tool to assist in this step.
  9. Lenovo IdeaPad 330S-14IKB Fan Replacement: 手順 9、 2の画像 1 Lenovo IdeaPad 330S-14IKB Fan Replacement: 手順 9、 2の画像 2
    • Disconnect the large black wire connected to the slot on the side of your fan.
    • Remove your fan.
終わりに
3 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
sal
メンバー登録日: 10/02/23
459 ポイント
2のガイドは作成済み
チーム
Linn Benton Community College, Team 1-3, Karnes Fall 2023 Linn Benton Community College, Team 1-3, Karnes Fall 2023人のメンバー
LBCC-KARNES-F23S1G3
5 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 13
過去 30 日: 27
今までの合計 160
