メインコンテンツにスキップ
Lenovo IdeaPad 330S Fan and Thermal Unit
必要な工具と部品
  1. Lenovo IdeaPad 330S Fan and Thermal Unit, Removing bottom case: 手順 1、 2の画像 1 Lenovo IdeaPad 330S Fan and Thermal Unit, Removing bottom case: 手順 1、 2の画像 2
    • Turn off the device and disconnect from the power.
    • Remove the 10 screws as shown in picture.
    • Using a plastic pry tool remove the bottom case (gently).
  2. Lenovo IdeaPad 330S Fan and Thermal Unit, Disconnecting Battery: 手順 2、 1の画像 1
    • Using a spudger gently push the black connector to the left (red circle).
    • If you want to remove the battery by removing the five screws labeled in blue.
  3. Lenovo IdeaPad 330S Fan and Thermal Unit, Removing guard shield: 手順 3、 2の画像 1 Lenovo IdeaPad 330S Fan and Thermal Unit, Removing guard shield: 手順 3、 2の画像 2
    • Remove the 3 screws that are circuled in blue. Then remove the red one.
    • The red circle is a M2.5 and the blue circle are M2.0 those are different screws!
    • Remove the black shield
  4. Lenovo IdeaPad 330S Fan and Thermal Unit, Removing Cooling Fan: 手順 4、 1の画像 1
    • Remove the two black screws that are marked in red
    • Disconnect the fan (blue marker) from MB by pushing gently to the left using a spudger.
  5. Lenovo IdeaPad 330S Fan and Thermal Unit, Removing the Thermal unit: 手順 5、 1の画像 1
    • Remove the 6 screws in revrse of the number stated on screws.
    • Replace the thermal paste with a fresh one
    • Removing the fan is not needed but will help with easier dissemble of thermal unit
終わりに
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Ilia Tocheny
メンバー登録日: 04/30/19
1,616 ポイント
9のガイドは作成済み
2 件のコメント
I want to buy this piece, where can I find it for purchase?
c.lobos_7 - 返信
Good question, you could try at your local Lenovo Service provider.
Ilia Tocheny - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 13
今までの合計 1,586
