メインコンテンツにスキップ
Lenovo IdeaPad 330-15IGM Speaker Units Replacement
必要な工具と部品
  1. Lenovo IdeaPad 330-15IGM Speaker Units Replacement, Back Cover: 手順 1、 3の画像 1 Lenovo IdeaPad 330-15IGM Speaker Units Replacement, Back Cover: 手順 1、 3の画像 2 Lenovo IdeaPad 330-15IGM Speaker Units Replacement, Back Cover: 手順 1、 3の画像 3
    • Press and hold the power button to power off the computer.
  2. Lenovo IdeaPad 330-15IGM Speaker Units Replacement: 手順 2、 1の画像 1
    • Remove thirteen 6.5 mm screws from the laptop cover using a Phillips #00 screwdriver.
  3. Lenovo IdeaPad 330-15IGM Speaker Units Replacement: 手順 3、 1の画像 1
    • Use your hands to remove the back cover from the laptop.
  4. Lenovo IdeaPad 330-15IGM Speaker Units Replacement, Battery: 手順 4、 1の画像 1
    • Remove four 5.7 mm screws that hold the battery unit in place using a Phillips #00 screwdriver.
  5. Lenovo IdeaPad 330-15IGM Speaker Units Replacement: 手順 5、 3の画像 1 Lenovo IdeaPad 330-15IGM Speaker Units Replacement: 手順 5、 3の画像 2 Lenovo IdeaPad 330-15IGM Speaker Units Replacement: 手順 5、 3の画像 3
    • Detach the cable connecting the battery to the motherboard.
  6. Lenovo IdeaPad 330-15IGM Speaker Units Replacement: 手順 6、 1の画像 1
    • Remove the battery from the laptop.
  7. Lenovo IdeaPad 330-15IGM Speaker Units Replacement, Speaker Units: 手順 7、 2の画像 1 Lenovo IdeaPad 330-15IGM Speaker Units Replacement, Speaker Units: 手順 7、 2の画像 2
    • Carefully disconnect the speaker from the motherboard.
    • Each speaker unit has blue stoppers that allow it to remain in place. In order to remove the unit, you must nudge the blue stoppers off of the plastic piece it is attached to. Repeat for each speaker.
  8. Lenovo IdeaPad 330-15IGM Speaker Units Replacement: 手順 8、 3の画像 1 Lenovo IdeaPad 330-15IGM Speaker Units Replacement: 手順 8、 3の画像 2 Lenovo IdeaPad 330-15IGM Speaker Units Replacement: 手順 8、 3の画像 3
    • Remove the unit from the chassis and carefully remove the cable that connects the two speaker units together.
    • This cable is vital since it is the only thing that connects the speaker units and allows them to share audio from the motherboard.
終わりに
作成者
1人の作成者と共同作成されました。
Emmanuel Guadarrama
メンバー登録日: 08/24/22
457 ポイント
5のガイドは作成済み
チーム
Gateway, Team 1-2, Class Fall 2022 Gateway, Team 1-2, Class Fall 2022人のメンバー
GCC-CLASS-F22S1G2
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 15
今までの合計 121
