はじめに
Use this guide to replace the battery in your Lenovo IdeaPad 3-15ADA05. Before using this guide, be sure to review the troubleshooting page to ensure the battery is the problem. If the computer was recently used, ensure it is powered off before attempting the replacement.
必要な工具と部品
Remove the six M2 x 5mm screws located at the top half of the laptop using a #0 Phillips head, then remove the four M2 x 2.5mm screws located at the bottom of the laptop using a #0 Phillips head.
もう少しです!
終わりに
