メインコンテンツにスキップ
Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement
必要な工具と部品
  1. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement, Lower Case: 手順 1、 1の画像 1
    • First, before you do anything, make sure the computer has been turned off and unplugged.
    • Place the the computer bottom facing up. Unscrew the eleven 6 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: 手順 2、 2の画像 1 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: 手順 2、 2の画像 2
    • Use an opening tool to gently disconnect the clips on the side of the back panel.
    • DO NOT try to force open the panel, as this may cause damage to it.
  3. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: 手順 3、 2の画像 1 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: 手順 3、 2の画像 2
    • Pry out the optical drive opposite of the laptop.
    • Since the screws have already been removed, you will not need to worry about any more screws on the optical drive.
  4. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: 手順 4、 3の画像 1 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: 手順 4、 3の画像 2 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: 手順 4、 3の画像 3
    • Release the remaining clasp and remove the lower case.
  5. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement, Hard Disk Drive (HDD): 手順 5、 1の画像 1
    • Use a Phillips #1 screwdriver to unscrew the four 5 mm screws that are holding the hard drive in place.
  6. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: 手順 6、 2の画像 1 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: 手順 6、 2の画像 2
    • Do not lift the hard drive straight up; this might break the connection port.
    • Softly slide the hard drive away from the port.
  7. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: 手順 7、 2の画像 1 Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: 手順 7、 2の画像 2
    • Use a Phillips #1 screwdriver remove the 2 screws from both sides of the hard drive (total of 4 screws).
  8. Lenovo IdeaPad 110-17IKB Hard Disk Drive Replacement: 手順 8、 1の画像 1
    • Remove the hard drive from the housing mount.
終わりに
作成者
2人の作成者と共同で作成されました。
Cameron Mounce
メンバー登録日: 09/05/23
668 ポイント
5のガイドは作成済み
チーム
Gateway, Team 1-3, Pee Fall 2023 Gateway, Team 1-3, Pee Fall 2023人のメンバー
GCC-PEE-F23S1G3
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 118
