メインコンテンツにスキップ
Lenovo IdeaPad 110 Touch-15ACL Screen Replacement
必要な工具と部品
  1. Lenovo IdeaPad 110 Touch-15ACL Screen Replacement, Back Case: 手順 1、 1の画像 1
    • Remove the thirteen 6 mm Phillips #0 screws.
  2. Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: 手順 2、 2の画像 1 Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: 手順 2、 2の画像 2
    • Use an opening tool to gently disconnect most of the clips on the back panel.
    • DO NOT force the panel out towards the optical disk drive.
  3. Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: 手順 3、 3の画像 1 Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: 手順 3、 3の画像 2 Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: 手順 3、 3の画像 3
    • Pry the disk drive away from the center of the laptop.
    • Don't worry about any screws since we already removed the screws that are associated with the drive.
    • Once the drive is removed, remove the one 2 mm Phillips #0 screw that is now exposed.
  4. Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: 手順 4、 3の画像 1 Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: 手順 4、 3の画像 2 Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: 手順 4、 3の画像 3
    • Unclip any of the remaining clips and remove the back panel.
  5. Lenovo IdeaPad 110 Touch-15ACL Screen Replacement, Battery Replacement: 手順 5、 1の画像 1
    • Remove the four 6 mm Phillips #0 mounting screws.
  6. Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: 手順 6、 3の画像 1 Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: 手順 6、 3の画像 2 Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: 手順 6、 3の画像 3
    • Detach the wire connected to the motherboard and remove the battery assembly.
  7. Lenovo IdeaPad 110 Touch-15ACL Screen Replacement, Screen Replacement: 手順 7、 3の画像 1 Lenovo IdeaPad 110 Touch-15ACL Screen Replacement, Screen Replacement: 手順 7、 3の画像 2 Lenovo IdeaPad 110 Touch-15ACL Screen Replacement, Screen Replacement: 手順 7、 3の画像 3
    • Open the laptop so the screen is facing you.
    • Use a pick or spudger to detach the clips around the screen holding the bezel in place.
    • Remove the bezel.
  8. Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: 手順 8、 3の画像 1 Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: 手順 8、 3の画像 2 Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: 手順 8、 3の画像 3
    • Remove the four 3 mm size Phillips #0 mounting screws.
  9. Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: 手順 9、 3の画像 1 Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: 手順 9、 3の画像 2 Lenovo IdeaPad 110 Touch-15ACL Screen Replacement: 手順 9、 3の画像 3
    • Carefully detach the display cable that attaches to the display.
    • There may be a piece of tape covering the connection. Be sure to preserve this if possible—it ensures a proper connection to your display.
終わりに
作成者
6人の作成者と共同で作成されました。
Clark Beuckman
メンバー登録日: 02/22/22
529 ポイント
5のガイドは作成済み
チーム
Clemson, Team 2-3, Hunter Spring 2022 Clemson, Team 2-3, Hunter Spring 2022人のメンバー
CLEM-HUNTER-S22S2G3
5 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 140
