メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
パーツ
パーツは指定されていません。
  1. Lay the computer down on its side as shown.
    • Lay the computer down on its side as shown.
    • Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
  2. Gently slide the side panel straight back and remove from the computer.
    • Gently slide the side panel straight back and remove from the computer.
  3. Nintendo Switch 修理キット
    ゲームを再開するための、早くて簡単な修理キット
    Switch 修理キットページへ
    Switch 修理キットページへ
  4. Unplug both sets of wires attaching the power supply unit to the motherboard. The largest connection requires a significant amount of force to be removed.
    • Unplug both sets of wires attaching the power supply unit to the motherboard.
    • The largest connection requires a significant amount of force to be removed.
  5. Unplug all cords attached to the optical drive and hard drive. Unplug all cords attached to the optical drive and hard drive. Unplug all cords attached to the optical drive and hard drive.
    • Unplug all cords attached to the optical drive and hard drive.
  6. Using the Phillips #2 driver, unscrew the four 8mm screws attaching the power supply unit to the outside of the computer.
    • Using the Phillips #2 driver, unscrew the four 8mm screws attaching the power supply unit to the outside of the computer.
  7. Remove the power supply unit by pulling away from the screw side and then out.
    • Remove the power supply unit by pulling away from the screw side and then out.
終わりに
5 の人々がこのガイドを完成させました。
Timothy Grebe
メンバー登録日: 2014年10月19日
1,415 ポイント
9のガイドは作成済み
チーム
Cal Poly, Team 10-39, Amido Fall 2014 Cal Poly, Team 10-39, Amido Fall 2014人のメンバー
CPSU-AMIDO-F14S10G39
4 メンバー
18のガイドは作成済み
コメント1件
What part do I need to replace the POWER BUTTON, it's broke and have to press inside to power on?
Tracy Estes - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 23
今までの合計 2,735
