メインコンテンツにスキップ
Lenovo IdeaCentre K410 CPU Replacement
必要な工具と部品
  1. Lenovo IdeaCentre K410 CPU Replacement, Side Panel: 手順 1、 1の画像 1
    • Lay the computer down on its side as shown.
    • Remove the two 14mm screws shown. The screws are loose enough to unscrew with your hands.
  2. Lenovo IdeaCentre K410 CPU Replacement: 手順 2、 1の画像 1
    • Gently slide the side panel straight back and remove from the computer.
  3. Lenovo IdeaCentre K410 CPU Replacement, CPU Fan: 手順 3、 1の画像 1
    • Using the Phillips #00 Precision screwdriver, unscrew the four 12mm screws that hold the fan in place.
    • Be careful not to strip the screws.
    Fan does not need to be removed from the heat sink.
    Ken - 返信
  4. Lenovo IdeaCentre K410 CPU Replacement: 手順 4、 1の画像 1
    • Unplug the fan from the motherboard by gently pulling out the single plug. Then lift the fan up and out of the computer.
  5. Lenovo IdeaCentre K410 CPU Replacement, Heat Sink: 手順 5、 1の画像 1
    • Loosen the four screws that hold the heat sink in place using a Phillips #2 screwdriver.
    • The screws do not come all the way out of the heat sink
    • Pull the heat sink straight up to remove it.
    Loosen these four screws with the fan attached. Unplug the fan from the motherboard and remove the heat sink / fan as one component.
    Ken - 返信
  6. Lenovo IdeaCentre K410 CPU Replacement, CPU: 手順 6、 2の画像 1 Lenovo IdeaCentre K410 CPU Replacement, CPU: 手順 6、 2の画像 2
    • Remove the 2 8mm screws holding the CPU cover using a Torx #20 screwdriver.
    • Remove the 11 mm screw using a Torx #20 screwdriver.
    • Remove the cover and remove the CPU by gently pulling upward.
    Why not just lift the lever that allows the CPU cover to open to gain access to the CPU? Removing the cover is not necessary.
    Ken - 返信
終わりに
15 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Timothy Grebe
メンバー登録日: 10/19/14
1,634 ポイント
9のガイドは作成済み
チーム
Cal Poly, Team 10-39, Amido Fall 2014 Cal Poly, Team 10-39, Amido Fall 2014人のメンバー
CPSU-AMIDO-F14S10G39
4 メンバー
18のガイドは作成済み
コメント 1 件
Why would you remove the fan and the CPU fixation bracket when you could just remove the heatsink by unscrewing it and then lift up the bracket lever...
alphaLONE - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 37
今までの合計 3,807
