メインコンテンツにスキップ
Lenovo Horizon 2s Speaker Replacement
必要な工具と部品
  1. Lenovo Horizon 2s Speaker Replacement, Rear Case: 手順 1、 3の画像 1 Lenovo Horizon 2s Speaker Replacement, Rear Case: 手順 1、 3の画像 2 Lenovo Horizon 2s Speaker Replacement, Rear Case: 手順 1、 3の画像 3
    • Flip the device so the rear case is facing upward.
    • With the plastic opening tool carefully pry the plastic piece shown in the picture, until it is completely removed from the case.
  2. Lenovo Horizon 2s Speaker Replacement: 手順 2、 2の画像 1 Lenovo Horizon 2s Speaker Replacement: 手順 2、 2の画像 2
    • Using your fingers, carefully remove the rubber boot from the right side of the rear case.
    • With the Phillips #1 head, remove the screw placed directly under the rubber boot.
  3. Lenovo Horizon 2s Speaker Replacement: 手順 3、 1の画像 1
    • Using the plastic opening tool, push the display screen on the device forward until it separates from the rear casing.
  4. Lenovo Horizon 2s Speaker Replacement: 手順 4、 1の画像 1
    • Using the plastic opening tool, carefully pry around the perimeter of the screen until the entire screen is completely separated from the rear casing.
  5. Lenovo Horizon 2s Speaker Replacement: 手順 5、 3の画像 1 Lenovo Horizon 2s Speaker Replacement: 手順 5、 3の画像 2 Lenovo Horizon 2s Speaker Replacement: 手順 5、 3の画像 3
    • Before completely separating the screen from the rear casing you will carefully detach two wires that are connected to both sides of the device. This will allow you to completely separate the rear casing from screen.
  6. Lenovo Horizon 2s Speaker Replacement, Speaker: 手順 6、 2の画像 1 Lenovo Horizon 2s Speaker Replacement, Speaker: 手順 6、 2の画像 2
    • Locate the intertwined black and red wires that connect the two small, black speakers and the motherboard, as shown in the picture.
    • Disconnect this wire from the motherboard by carefully pulling it out.
  7. Lenovo Horizon 2s Speaker Replacement: 手順 7、 3の画像 1 Lenovo Horizon 2s Speaker Replacement: 手順 7、 3の画像 2 Lenovo Horizon 2s Speaker Replacement: 手順 7、 3の画像 3
    • Locate the speakers along the bottom of the device.
    • The speakers are connected by two knobs on each side. Carefully lift the speakers to detach them from the tablet.
  8. Lenovo Horizon 2s Speaker Replacement: 手順 8、 1の画像 1
    • Finally, locate the tape that keeps the speaker wires in the grooves of the device.
    • Peel the tape off as shown and your speakers are now completely disconnected from the tablet.
終わりに
作成者
4人の作成者と共同で作成されました。
Zak Kazakos
メンバー登録日: 09/25/17
320 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team S3-G6, Cannon Fall 2017 USF Tampa, Team S3-G6, Cannon Fall 2017人のメンバー
USFT-CANNON-F17S3G6
3 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 7
今までの合計 272
