メインコンテンツにスキップ
Lenovo Horizon 2s Fan and Heat-sink Replacement
必要な工具と部品
  1. Lenovo Horizon 2s Fan and Heat-sink Replacement, Rear Case: 手順 1、 3の画像 1 Lenovo Horizon 2s Fan and Heat-sink Replacement, Rear Case: 手順 1、 3の画像 2 Lenovo Horizon 2s Fan and Heat-sink Replacement, Rear Case: 手順 1、 3の画像 3
    • Flip the device so the rear case is facing upward.
    • With the plastic opening tool carefully pry the plastic piece shown in the picture, until it is completely removed from the case.
  2. Lenovo Horizon 2s Fan and Heat-sink Replacement: 手順 2、 2の画像 1 Lenovo Horizon 2s Fan and Heat-sink Replacement: 手順 2、 2の画像 2
    • Using your fingers, carefully remove the rubber boot from the right side of the rear case.
    • With the Phillips #1 head, remove the screw placed directly under the rubber boot.
  3. Lenovo Horizon 2s Fan and Heat-sink Replacement: 手順 3、 1の画像 1
    • Using the plastic opening tool, push the display screen on the device forward until it separates from the rear casing.
  4. Lenovo Horizon 2s Fan and Heat-sink Replacement: 手順 4、 1の画像 1
    • Using the plastic opening tool, carefully pry around the perimeter of the screen until the entire screen is completely separated from the rear casing.
  5. Lenovo Horizon 2s Fan and Heat-sink Replacement: 手順 5、 3の画像 1 Lenovo Horizon 2s Fan and Heat-sink Replacement: 手順 5、 3の画像 2 Lenovo Horizon 2s Fan and Heat-sink Replacement: 手順 5、 3の画像 3
    • Before completely separating the screen from the rear casing you will carefully detach two wires that are connected to both sides of the device. This will allow you to completely separate the rear casing from screen.
  6. Lenovo Horizon 2s Fan and Heat-sink Replacement, HDD: 手順 6、 2の画像 1 Lenovo Horizon 2s Fan and Heat-sink Replacement, HDD: 手順 6、 2の画像 2
    • Using your Philips head screw driver with the number 1 head. Carefully unscrew the four M2-6mm screws that are circled in the picture.
  7. Lenovo Horizon 2s Fan and Heat-sink Replacement: 手順 7、 1の画像 1
    • Now carefully lift the hard-drive that is still attached to the boot from the rear casing.
  8. Lenovo Horizon 2s Fan and Heat-sink Replacement: 手順 8、 2の画像 1 Lenovo Horizon 2s Fan and Heat-sink Replacement: 手順 8、 2の画像 2
    • Now that the hard-drive is detached from the rear casing you will still have to detach the hard-drive from its boot. Again using the Philips screwdriver with the number one head. Carefully unscrew the four M2-6mm screws that are circled in the picture.
  9. Lenovo Horizon 2s Fan and Heat-sink Replacement: 手順 9、 1の画像 1
    • Now that the screws are detached. You can now carefully lift the hard-drive from the metal boot.
  10. Lenovo Horizon 2s Fan and Heat-sink Replacement, Battery: 手順 10、 1の画像 1
    • Using your fingers carefully and slowly disconnect the wire shown here from the motherboard.
  11. Lenovo Horizon 2s Fan and Heat-sink Replacement: 手順 11、 2の画像 1 Lenovo Horizon 2s Fan and Heat-sink Replacement: 手順 11、 2の画像 2
    • Using the Philips screw driver with the number 1 head. Carefully unscrew the six M2- 6mm screws that are circled in the picture.
  12. Lenovo Horizon 2s Fan and Heat-sink Replacement: 手順 12、 1の画像 1
    • Carefully lift the battery from the rear casing.
  13. Lenovo Horizon 2s Fan and Heat-sink Replacement, Fan and Heat-sink: 手順 13、 2の画像 1 Lenovo Horizon 2s Fan and Heat-sink Replacement, Fan and Heat-sink: 手順 13、 2の画像 2
    • With the Phillips screw driver using the number one head. Carefully unscrew the the M2-6mm wire fastener, so the wires shown in the picture can be released from the rear casing.
  14. Lenovo Horizon 2s Fan and Heat-sink Replacement: 手順 14、 1の画像 1
    • With the Phillips screwdriver using the number one head carefully unscrew the four M2 6mm screws circled in the picture.
  15. Lenovo Horizon 2s Fan and Heat-sink Replacement: 手順 15、 1の画像 1
    • With the screws detached carefully lift the heat sink off the CPU on the motherboard.
  16. Lenovo Horizon 2s Fan and Heat-sink Replacement: 手順 16、 2の画像 1 Lenovo Horizon 2s Fan and Heat-sink Replacement: 手順 16、 2の画像 2
    • With a Phillips #1 screwdriver, unscrew the six M2 6mm screws located around the fans, as shown.
  17. Lenovo Horizon 2s Fan and Heat-sink Replacement: 手順 17、 1の画像 1
    • Carefully remove the power plugs connecting the fans to the motherboard.
  18. Lenovo Horizon 2s Fan and Heat-sink Replacement: 手順 18、 1の画像 1
    • Lift the fans carefully out of the casing.
終わりに
作成者
3人の作成者と共同で作成されました。
Cody Rubel
メンバー登録日: 09/25/17
214 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team S3-G6, Cannon Fall 2017 USF Tampa, Team S3-G6, Cannon Fall 2017人のメンバー
USFT-CANNON-F17S3G6
3 メンバー
12のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 808
