メインコンテンツにスキップ
Lenovo Horizon 2s Battery Replacement
  1. Lenovo Horizon 2s Battery Replacement, Rear Case: 手順 1、 3の画像 1 Lenovo Horizon 2s Battery Replacement, Rear Case: 手順 1、 3の画像 2 Lenovo Horizon 2s Battery Replacement, Rear Case: 手順 1、 3の画像 3
    • Flip the device so the rear case is facing upward.
    • With the plastic opening tool carefully pry the plastic piece shown in the picture, until it is completely removed from the case.
  2. Lenovo Horizon 2s Battery Replacement: 手順 2、 2の画像 1 Lenovo Horizon 2s Battery Replacement: 手順 2、 2の画像 2
    • Using your fingers, carefully remove the rubber boot from the right side of the rear case.
    • With the Phillips #1 head, remove the screw placed directly under the rubber boot.
  3. Lenovo Horizon 2s Battery Replacement: 手順 3、 1の画像 1
    • Using the plastic opening tool, push the display screen on the device forward until it separates from the rear casing.
  4. Lenovo Horizon 2s Battery Replacement: 手順 4、 1の画像 1
    • Using the plastic opening tool, carefully pry around the perimeter of the screen until the entire screen is completely separated from the rear casing.
  5. Lenovo Horizon 2s Battery Replacement: 手順 5、 3の画像 1 Lenovo Horizon 2s Battery Replacement: 手順 5、 3の画像 2 Lenovo Horizon 2s Battery Replacement: 手順 5、 3の画像 3
    • Before completely separating the screen from the rear casing you will carefully detach two wires that are connected to both sides of the device. This will allow you to completely separate the rear casing from screen.
  6. Lenovo Horizon 2s Battery Replacement, Battery: 手順 6、 1の画像 1
    • Using your fingers carefully and slowly disconnect the wire shown here from the motherboard.
  7. Lenovo Horizon 2s Battery Replacement: 手順 7、 2の画像 1 Lenovo Horizon 2s Battery Replacement: 手順 7、 2の画像 2
    • Using the Philips screw driver with the number 1 head. Carefully unscrew the six M2- 6mm screws that are circled in the picture.
  8. Lenovo Horizon 2s Battery Replacement: 手順 8、 1の画像 1
    • Carefully lift the battery from the rear casing.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Dustin Carro
メンバー登録日: 09/25/17
224 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team S3-G6, Cannon Fall 2017 USF Tampa, Team S3-G6, Cannon Fall 2017人のメンバー
USFT-CANNON-F17S3G6
3 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 13
今までの合計 1,572
