メインコンテンツにスキップ
Lenovo G70-80 Screen Replacement
必要な工具と部品
  1. Lenovo G70-80 Screen Replacement, Battery: 手順 1、 1の画像 1
    • Turn off the computer.
    • Set the computer upside down with the back facing up.
  2. Lenovo G70-80 Screen Replacement: 手順 2、 2の画像 1 Lenovo G70-80 Screen Replacement: 手順 2、 2の画像 2
    • Located directly below the bottom plate will be two switches near where the battery is located.
    • With the battery facing you, slide the battery switch on the right side of the laptop towards the right.
    • To ensure the switch on the right is unlocked, look for a red indicator next to the switch.
  3. Lenovo G70-80 Screen Replacement: 手順 3、 2の画像 1 Lenovo G70-80 Screen Replacement: 手順 3、 2の画像 2
    • Slide the left battery release switch to the left.
    • While holding the switch to the left, lift the battery to remove it from the computer.
  4. Lenovo G70-80 Screen Replacement: 手順 4、 2の画像 1 Lenovo G70-80 Screen Replacement: 手順 4、 2の画像 2
    • Remove the battery.
  5. Lenovo G70-80 Screen Replacement, Screen: 手順 5、 1の画像 1
    • Open the laptop to face the screen.
  6. Lenovo G70-80 Screen Replacement: 手順 6、 3の画像 1 Lenovo G70-80 Screen Replacement: 手順 6、 3の画像 2 Lenovo G70-80 Screen Replacement: 手順 6、 3の画像 3
    • Use a plastic opening tool to pull the bezel forward and release it from the top of the LCD panel.
    • The bezel is the plastic frame around the laptop screen.
  7. Lenovo G70-80 Screen Replacement: 手順 7、 2の画像 1 Lenovo G70-80 Screen Replacement: 手順 7、 2の画像 2
    • After the top part of the bezel is released, use the plastic opening tool to completely remove the bezel.
    • If you are having trouble removing the bezel from the LCD panel, pull both sides of the bezel towards you with your hands.
  8. Lenovo G70-80 Screen Replacement: 手順 8、 3の画像 1 Lenovo G70-80 Screen Replacement: 手順 8、 3の画像 2 Lenovo G70-80 Screen Replacement: 手順 8、 3の画像 3
    • Use a screwdriver to remove the screws that secure the LCD panel to the computer.
    • Once the bezel is removed, you will see eight screws around the screen that secure the LCD panel to the computer.
  9. Lenovo G70-80 Screen Replacement: 手順 9、 1の画像 1
    • Carefully separate the LCD panel from the plastic cover, placing it face down on the keyboard
  10. Lenovo G70-80 Screen Replacement: 手順 10、 1の画像 1
    • Disconnect the LCD panel from the computer by peeling the connector off.
  11. Lenovo G70-80 Screen Replacement: 手順 11、 2の画像 1 Lenovo G70-80 Screen Replacement: 手順 11、 2の画像 2
    • With a screwdriver, remove the four screws that mount the LCD panel onto the mounting arms.
    • There is one screw on each corner that connects to the mounting arms.
  12. Lenovo G70-80 Screen Replacement: 手順 12、 1の画像 1
    • Remove the LCD panel.
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Alexis Buford
メンバー登録日: 02/28/17
665 ポイント
5のガイドは作成済み
チーム
Carson-Newman University, Team S1-G2, Sobiech Spring 2017 Carson-Newman University, Team S1-G2, Sobiech Spring 2017人のメンバー
CNU-SOBIECH-S17S1G2
3 メンバー
5のガイドは作成済み
コメント 1 件
how do you repair a whitescreen effect for a lenovo110 ideapad
sidney ifedha - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 12
過去 30 日: 18
今までの合計 1,711
