メインコンテンツにスキップ
Lenovo G40-30 Keyboard Replacement
必要な工具と部品
  1. Lenovo G40-30 Keyboard Replacement, Battery: 手順 1、 3の画像 1 Lenovo G40-30 Keyboard Replacement, Battery: 手順 1、 3の画像 2 Lenovo G40-30 Keyboard Replacement, Battery: 手順 1、 3の画像 3
    • At the top of the laptop you will see two switches, like in image one and two.
    • Pull the switches outwards with your thumb, towards the unlocked lock.
  2. Lenovo G40-30 Keyboard Replacement: 手順 2、 3の画像 1 Lenovo G40-30 Keyboard Replacement: 手順 2、 3の画像 2 Lenovo G40-30 Keyboard Replacement: 手順 2、 3の画像 3
    • Once both switches are pulled, the battery should pop out.
  3. Lenovo G40-30 Keyboard Replacement: 手順 3、 1の画像 1
    • Now you are ready to insert your new battery.
  4. Lenovo G40-30 Keyboard Replacement, Keyboard: 手順 4、 2の画像 1 Lenovo G40-30 Keyboard Replacement, Keyboard: 手順 4、 2の画像 2
    • Use a JIS #1 screwdriver to remove the two 7 mm screws.
  5. Lenovo G40-30 Keyboard Replacement: 手順 5、 2の画像 1 Lenovo G40-30 Keyboard Replacement: 手順 5、 2の画像 2
    • Remove the back panel by sliding it away from the battery.
  6. Lenovo G40-30 Keyboard Replacement: 手順 6、 1の画像 1
    • Use a JIS #1 screwdriver to remove the three 7 mm screws.
  7. Lenovo G40-30 Keyboard Replacement: 手順 7、 2の画像 1 Lenovo G40-30 Keyboard Replacement: 手順 7、 2の画像 2
    • Wedge the plastic opening tool in-between the keyboard and the base of the laptop.
    • Continue using the plastic opening tool to pry around the edge until the keyboard is completely freed form the frame.
    • The keyboard should only be connected by a ribbon on the underside of the keyboard.
    • It is recommended that you slowly pull the keyboard out as your move around the edge. As in picture 2.
    • Be careful not to pull the keyboard too far away from the face as it will damage the data ribbon.
  8. Lenovo G40-30 Keyboard Replacement: 手順 8、 3の画像 1 Lenovo G40-30 Keyboard Replacement: 手順 8、 3の画像 2 Lenovo G40-30 Keyboard Replacement: 手順 8、 3の画像 3
    • Use the tweezers to lift the black hinge on the ribbon connector.
    • Then pull the ribbon from the connector and remove the keyboard from the laptop.
  9. Lenovo G40-30 Keyboard Replacement: 手順 9、 1の画像 1
    • Now your keyboard is free to be replaced!
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Luke
メンバー登録日: 02/08/18
314 ポイント
1ガイドが承認済み
チーム
Sam Houston State, Team S16-G4, Nardone Spring 2018 Sam Houston State, Team S16-G4, Nardone Spring 2018人のメンバー
SHSU-NARDONE-S18S16G4
5 メンバー
5のガイドは作成済み
コメント 1 件
thanks ….terimakasih sangat membantu…..
herman - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 10
今までの合計 2,082
