メインコンテンツにスキップ
Lenovo Flex 3-1120 Network Card Replacement
必要な工具と部品
  1. Lenovo Flex 3-1120 Network Card Replacement, Bottom Panel: 手順 1、 1の画像 1
    • Lay the computer down with the bottom panel facing up.
  2. Lenovo Flex 3-1120 Network Card Replacement: 手順 2、 2の画像 1 Lenovo Flex 3-1120 Network Card Replacement: 手順 2、 2の画像 2
    • Locate the ten 6mm Phillips screws along the edges and in the center of the back panel.
    • Remove all ten 6mm Phillips screws with a size 0 Phillips screwdriver.
  3. Lenovo Flex 3-1120 Network Card Replacement: 手順 3、 1の画像 1
    • Wedge the plastic opening tool into the small space under the back panel.
    • Use the plastic opening tool as a lever to separate the bottom panel from the computer.
    • Slide the tool along the edges of the computer until the bottom panel is completely separated.
    • You may start prying the bottom panel on any edge.
  4. Lenovo Flex 3-1120 Network Card Replacement: 手順 4、 1の画像 1
    • Lift the bottom panel off of the computer.
  5. Lenovo Flex 3-1120 Network Card Replacement, Network Card: 手順 5、 1の画像 1
    • Locate the network card on the top right of the computer.
  6. Lenovo Flex 3-1120 Network Card Replacement: 手順 6、 2の画像 1 Lenovo Flex 3-1120 Network Card Replacement: 手順 6、 2の画像 2
    • Locate the single 3.5mm Phillips head screw on the right edge of the network card.
    • Remove the single screw with a size 0 Phillips screwdriver.
  7. Lenovo Flex 3-1120 Network Card Replacement: 手順 7、 1の画像 1
    • Slide the network card out to the right to remove it from the motherboard.
  8. Lenovo Flex 3-1120 Network Card Replacement: 手順 8、 2の画像 1 Lenovo Flex 3-1120 Network Card Replacement: 手順 8、 2の画像 2
    • Locate the black and white antenna wires that are connected to the right edge of the network card.
    • Wiggle and pull upward on the two antenna cords connecting to the card to remove them.
終わりに
作成者
2人の作成者と共同で作成されました。
Geoff Bentz
メンバー登録日: 03/09/16
934 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team 7-1, Catania Spring 2016 UMass Dartmouth, Team 7-1, Catania Spring 2016人のメンバー
UMASSD-CATANIA-S16S7G1
4 メンバー
7のガイドは作成済み
コメント 1 件
Where can I buy a replacement card? Can I replace the AC-3160 with the newer 7265D card?
barence321 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 5
今までの合計 788
