はじめに
This guide will show you how to remove the motherboard. Removal of the motherboard is necessary in order to replace the thermal compound on the processor. Prerequisite only.
必要な工具と部品
Pull the connector out of its port on the motherboard.
Locate the power input cable on the top right corner of the motherboard.
Remove the power input cable by gently sliding each side of the cable out of its port. Alternate between the left and right sides of the cable until it disconnects.
Locate the ribbon cable with a blue tab on it. The cable is connected to the right edge of the motherboard.
Lift up the black latch with the spudger.
Pull on the blue tab to the left to remove the cable.
Locate the three 4.5mm screws that are securing the bracket in the top left corner of the motherboard.
Locate the four 3.5mm screws holding the motherboard in place.
Remove all of the screws with a size 0 Phillips screwdriver.
3 の人々がこのガイドを完成させました。
コメント 1 件
One important thing that is not noted is to remove the NIC before removing the MOBO. The NIC is attached to the Top Plate with a single screw and needs to be removed before attempting to remove the MOBO.
