この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
The hard drive is likely to malfunction when dropped or put under a lot of stress. If the computer won't boot and is having hard disk/hard drive reading errors, follow this guide to replace it.
必要な工具と部品
Turn off the computer.
Disconnect the charging cable from the computer.
Flip the computer upside down.
8 の人々がこのガイドを完成させました。
2 件のコメント
In step 1, failure to unplug the cable does not result in electric shock. The power supply voltage is too low for such shock to happen to a human, but it can cause electrical damage to the motherboard. It is always a safe procedure to work on any machine unpowered (both power supply and battery disconnected and/or removed).
In step 9, be sure to remember the direction that the original drive was pointing when removing. The new drive must point the same direction.
rayramirez - 返信
