はじめに
The RAM card should be replaced if the computer won't boot, or if the computer is not running at an optimal speed. Replacing the RAM card for this laptop is a fairly easy process..
必要な工具と部品
Turn off the computer.
Disconnect the charger from the computer.
Flip the computer upside down.
Using the Phillips #00 Screwdriver, Loosen the five 5.4 mm screws around the back panel from the laptop.
ある他の人がこのガイドを完成しました。
