コンピュータの電源を切ります。
コンピュータからチャージャーの接続を外します。
コンピュータを裏返して、置きます。
Using the Phillips #0 Screwdriver, remove the six 4.3 mm screws that connect display screen to the rear bezel.
There are two screws in the bottom left and right corners of the frame.
Lay display panel face down on the keyboard.
Peel back the flat wire that has the camera's ZIF connector until it is loose from the back of the display.
Carefully peel of the clear adhesive tape attached to the primary display ZIF connector using a plastic spudger.
Place the metal tweezer tips between the ZIF connector and the wire-to-board connection.
Carefully separate ZIF wire-to-board connection by pulling metal tweezers in a downward motion.
Pull up on flat wire until display is completely disconnected.
Be very careful when separating ZIF connections . The ends of the ZIF wire connectors are delicate and can break easily.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
