メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
The back panel of the Lenovo B575-1450 allows you access to other internal components that can be replace in this laptop.
パーツ
パーツは指定されていません。
  1. Turn off the computer.
    • Turn off the computer.
    • Disconnect the charger from the computer.
    • Flip the computer upside down.
  2. Push the right-hand switch outward into the "unlocked" position. Push the right-hand switch outward into the "unlocked" position.
    • Push the right-hand switch outward into the "unlocked" position.
  3. While holding the battery, use your other hand to push the left clip to the left and pull the battery out. While holding the battery, use your other hand to push the left clip to the left and pull the battery out. While holding the battery, use your other hand to push the left clip to the left and pull the battery out.
    • While holding the battery, use your other hand to push the left clip to the left and pull the battery out.
  4. The screws are captive to the back panel so they are not to be removed. Using the Phillips #00 Screwdriver,  Loosen the five 5.4 mm screws around the back panel from the laptop.
    • The screws are captive to the back panel so they are not to be removed.
    • Using the Phillips #00 Screwdriver, Loosen the five 5.4 mm screws around the back panel from the laptop.
  5. Using a plastic opening tool, pry the back panel from the laptop.
    • Using a plastic opening tool, pry the back panel from the laptop.
  6. Pull the panel outward from the rest of the laptop. The inside of the laptop will be exposed. From here you can access the CD-ROM drive, hard drive, and Keyboard.
    • Pull the panel outward from the rest of the laptop. The inside of the laptop will be exposed. From here you can access the CD-ROM drive, hard drive, and Keyboard.
終わりに
2 の人々がこのガイドを完成させました。
Carlo Calvillo
メンバー登録日: 2016年09月26日
742 ポイント
6のガイドは作成済み
チーム
Eastern Washington University, Team 1-4, Crane Fall 2016 Eastern Washington University, Team 1-4, Crane Fall 2016人のメンバー
EWU-CRANE-F16S1G4
4 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 11
今までの合計 911
