メインコンテンツにスキップ
Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement
必要な工具と部品
ビデオの概要
  1. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Battery: 手順 1、 1の画像 1
    • Switch off the laptop, disconnect the AC adapter, and remove the battery.
  2. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Memory / HDD cover: 手順 2、 2の画像 1 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Memory / HDD cover: 手順 2、 2の画像 2
    • Remove the screws securing the Memory / HDD cover.
    • Slide the cover down and remove it.
  3. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Memory Modules: 手順 3、 2の画像 1 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Memory Modules: 手順 3、 2の画像 2
    • To pop up the memory module you’ll have to spread latches on both sides of the slot.
    • MEMORY
    • Speed 1600 MHz / PC3L-12800
    • Technology DDR3L SDRAM SODIMM
    • Max Supported Size 16 GB
    • Form Factor SO-DIMM 204-pin
    • Slots Qty 2
    • Empty Slots 1
  4. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Hard Disk Drive (HDD): 手順 4、 3の画像 1 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Hard Disk Drive (HDD): 手順 4、 3の画像 2 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Hard Disk Drive (HDD): 手順 4、 3の画像 3
    • Remove two screws securing the hard drive mounting bracked.
    • Slide the HDD to the left to disconnect it from the motherboard and remove it from the device.
    • Remove two screws on each side of the HDD to remove the mounting bracket.
    • Now you have to transfer the mounting bracket to the new HDD or SSD.
  5. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Wireless / Bluetooth Card: 手順 5、 2の画像 1 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, Wireless / Bluetooth Card: 手順 5、 2の画像 2
    • Remove the screw and disconnect the two coaxial antenna cables from the WiFi card.
    • Pop it up and remove it from the slot.
    • Wireless N M.2, or Next Generation Form Factor (NGFF) Card.
  6. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, CMOS Battery: 手順 6、 3の画像 1 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, CMOS Battery: 手順 6、 3の画像 2 Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement, CMOS Battery: 手順 6、 3の画像 3
    • Complementary Metal-Oxide-Semiconductor (CMOS) aka Real-Time Clock (RTC)
    • CR2032
  7. Lenovo B50 HDD, RAM, WiFi, CMOS Battery Replacement: 手順 7、 1の画像 1
    • That's all.
終わりに
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
ZFix
メンバー登録日: 12/09/13
191,368 ポイント
330のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
322 メンバー
2,545のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 21
過去 30 日: 65
今までの合計 7,280
