メインコンテンツにスキップ
Lenovo A7-40, A7-50 A3500 Factory Reset
必要な工具と部品
ビデオの概要
  1. Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 1: 手順 1、 3の画像 1 Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 1: 手順 1、 3の画像 2 Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 1: 手順 1、 3の画像 3
    • 1. Switch of the tablet. If the device freezes, you can use a reset hole under the memory card reader cover.
    • 2. Press and hod: Volume Up + Volume Down + Power buttons.
    • 3. In the Recovery menu, use the Volume Down button to move the highlight and the Volume Up to select.
    • 4. Choose one by one: "wipe data/factory reset", "Yes -- delete all user data" and finally "reboot system now".
    when i press power key+volume up key nothing happened.. what can i do?
    samasdn - 返信
    My tab is rooted and I upgraded my lenovo tab 2
    shammas.vot - 返信
    so I hold the up and down volumes let's at the same time for 10. right?
    britt - 返信
    hold the up button on the Side and the the power button should that work?
    britt - 返信
    i did the instruction for a several times but nothings happened…the unlock pattern is still there….is there any way to fix it..
    khellyanne0929 - 返信
  2. Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 2: 手順 2、 3の画像 1 Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 2: 手順 2、 3の画像 2 Lenovo A7-40, A7-50 A3500 Factory Reset, Factory Reset - Method 2: 手順 2、 3の画像 3
    • 1. Switch off the tablet.
    • 2. Press and hold the Volume Up and Power On keys.
    • 3. When you feel release only the Power button. Now your device is in Factory mode.
    • 4. Use the Volume Up/Down keys for movement and the Power key for select.
    • 5. Select ¶§ eMMC (Clean eMMC)
    • Did you do it successfully?
    How can i change that language to english
    Clement Learn - 返信
    2nd variant helped thanx a lot
    edemko - 返信
    I pressed reset button and selected eMMC (only thing appearing in English alphabet). Thought when LENOVO appeared on screen that was previously just dark that I had successfully rebooted. Now, however, there is a spinning circle like you get when a video is buffering. This has been on for at least 15 minutes. What now??
    D. L. Perry - 返信
    I have the same case, what should I do ? Can u help me? Thanks!
    Peachengg00 -
    Please help me .tablet doent give recovery screen .it open all trial
    roshan_4ever2010 - 返信
終わりに
33 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
ZFix
メンバー登録日: 12/09/13
191,368 ポイント
330のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
321 メンバー
1,466のガイドは作成済み
17 件のコメント
let me try and see
usman aleeyu - 返信
Is it applicable to my lenovo a516?
valvinzon - 返信
yes it works thanks
abdullahjanajy - 返信
Love you so much goodnight baby
Van Prince -
Well thanks!! I was worried about my tab and now i can fix easily tab without paying others to fix my tab. Thank you again :))
Christian Lemuel Espenilla - 返信
my tablet is freezed and have no act on this way u said, i try a lot of internet advice , but still is not working , it is freezed
afshin Bahrami - 返信
will it remove all photos ??
Mahmoud Elnaggar - 返信
i have problem with my tab A3500
its restart alone without asking me
i try format it it but the problem still
what can i do
please help me
bandar baffan - 返信
I m still having problems rebooting it it just opens no android sign comes
Mohsin khan - 返信
After factory reset I don't habe any virtual keyboard an many alerts about google services not available.
What can I do?
fb - 返信
منتج رائع جدا جدا ويستحق الاقتناء
تحياتي
www.alex-translation.com/
مكتب ترجمة معتمد بالإسكندرية - الإسكندرية للترجمة المعتمدة - معتمد من السفارة الإمريكية
msmak22 - 返信
i have 1 problem, i have try all these methods and its not working, it because when i'm doing system update, it going to hard reset and i don't know what to chose, then i click "wipe cache partities" and then it going to black dead screen. i don't know why. please help me :( thank you. #sorry my bad english
Paulus Farrel - 返信
Started giving a high radiolike off frequency noise, then blanked out the screen and now does not power off nor reboot. Any hints?
-KP
Kim Pettersson - 返信
My tab A3500 has a problem,this pop out says "unfortunately lenovo launcher has stop" then I can not open all my apps,all the time is pop out blocks all apps,what will I do.am afraid to reformat cos I may lost all my pictures and data,please help me!!!
Thank you.
Jing Padernal - 返信
I have done the forementioned steps, but stuck on logo, will not start booting, any advice?
I have an Imac sierra osx
Thorstein Hansen - 返信
thank you♥ ♥ ♥ ♥ ♥ ♥ ♥ ♥ ♥ ♥ ♥ ♥ ♥ ♥ ♥ ♥
bad 3 - 返信
What's up brother and sister are Girls Good you are
Van Prince -
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 38
過去 30 日: 122
今までの合計 106,198
