メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Lenovo 300e Windows 2nd SSD Replacement
必要な工具と部品
  1. Lenovo 300e Windows 2nd SSD Replacement, Remove the bottom panel.: 手順 1、 1の画像 1
    • Flip the device upside down. Remove the bottom panel. Unscrew all 9 screws.
    • Some screws may not lift out of the panel. If this happens, simply loosen all screws and lift the entire panel off of the device.
    FixBotに聞いてみる
  2. Lenovo 300e Windows 2nd SSD Replacement, Unscrew the Storage Card.: 手順 2、 1の画像 1
    • Unscrew the screw holding the storage card in place.
    • Make sure you uncrew the right card. The card is located near the top. (assuming the battery is the closest to you) It isn't the one all the way at the top, it is below the one at the top and is slightly bigger.
    FixBotに聞いてみる
  3. Lenovo 300e Windows 2nd SSD Replacement, Remove and replace the Storage Card.: 手順 3、 2の画像 1 Lenovo 300e Windows 2nd SSD Replacement, Remove and replace the Storage Card.: 手順 3、 2の画像 2
    • Carefully wiggle the storage card out of the port.
    • Insert your replacement storage card and put the screw back in.
    • The card may sit on top of the spot where the screw enters. This is okay, as long as it is only the orangish/brownish part.
    • Put on the back panel by putting the screws in their original places and tightening them.
    FixBotに聞いてみる
終わりに
作成者
1人の作成者と共同作成されました。
Kyeler W
メンバー登録日: 03/04/25
3,116 ポイント
15のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 12
過去 30 日: 84
今までの合計 642
