メインコンテンツにスキップ
Lenovo 300e Chromebook 2nd Gen Battery Replacement
必要な工具と部品
  1. Lenovo 300e Chromebook 2nd Gen Battery Replacement, Opening The Chromebook: 手順 1、 3の画像 1 Lenovo 300e Chromebook 2nd Gen Battery Replacement, Opening The Chromebook: 手順 1、 3の画像 2 Lenovo 300e Chromebook 2nd Gen Battery Replacement, Opening The Chromebook: 手順 1、 3の画像 3
    この手順で使用する道具:
    Phillips #0 Screwdriver
    $5.49
    購入する
    • Make sure you power off your Chromebook first as you will be disconnecting the battery!
    • Remove all 9 screws on the back of the Chromebook with a Phillips #0 screwdriver
    • The screws circled on this Chromebook's back casing are all identical!
    • Use an opening tool such as a spudger and carefully work your way around the laptop to remove the back cover
  2. Lenovo 300e Chromebook 2nd Gen Battery Replacement, Disconnect the Battery: 手順 2、 2の画像 1 Lenovo 300e Chromebook 2nd Gen Battery Replacement, Disconnect the Battery: 手順 2、 2の画像 2
    • Remove the black tape covering the connector, then using a spudge tool, carefully unplug the battery from the motherboard
  3. Lenovo 300e Chromebook 2nd Gen Battery Replacement, Remove the battery: 手順 3、 2の画像 1 Lenovo 300e Chromebook 2nd Gen Battery Replacement, Remove the battery: 手順 3、 2の画像 2
    • Remove the 4 screws holding in the battery and set them aside
    • Make sure to separate the screws for the battery from the screws for the backing that were removed in the first step!
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Zachary Costello
メンバー登録日: 07/15/21
153 ポイント
1ガイドが承認済み
チーム
Zeeland Public Schools Zeeland Public Schools人のメンバー
Business
2 メンバー
1のガイドは作成済み
コメント 1 件
It should be mentioned that "newer" models of this particular Chromebook are/have been released. The Chromebooks' battery compartment's design have been slightly modified in that the battery compartment are now reversed.
So, since the battery's connector cable is so short, it's impossible to twist it to fit.
So, make sure you're getting the correct battery for the correct "model".
FYI, the "older" models have the power button close to the back corner of the device, and the "newer" models have the power button near the middle of the device.
Christopher Mali-Martinez - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 18
過去 30 日: 70
今までの合計 2,342
