メインコンテンツにスキップ
Lenovo 100e Chromebook Display Removal
必要な工具と部品
  1. Lenovo 100e Chromebook Display Removal, Remove back screws: 手順 1、 1の画像 1
    • use a 00 Philips head to remove the 10 screws holding the back of it.
  2. Lenovo 100e Chromebook Display Removal, remove back plate: 手順 2、 1の画像 1
    • Use the opening tool to pry the rear back plate off.
  3. Lenovo 100e Chromebook Display Removal, Disconnect and remove battery: 手順 3、 3の画像 1 Lenovo 100e Chromebook Display Removal, Disconnect and remove battery: 手順 3、 3の画像 2 Lenovo 100e Chromebook Display Removal, Disconnect and remove battery: 手順 3、 3の画像 3
    • 4 screws (00 Philips head)
    • 2 connectors from I/O (DB) to motherboard (DB)
    • battery to motherboard connection
  4. Lenovo 100e Chromebook Display Removal, Disconnect Ribbon Cable: 手順 4、 3の画像 1 Lenovo 100e Chromebook Display Removal, Disconnect Ribbon Cable: 手順 4、 3の画像 2 Lenovo 100e Chromebook Display Removal, Disconnect Ribbon Cable: 手順 4、 3の画像 3
    • For the ribbon cable, Carefully lift the locking flap on the connector, which secures the ribbon cable in place. These flaps are usually very delicate, so use a spudger or your fingernail to gently lift it up. It doesn’t come off entirely; just lifts up a little to release the tension on the cable.
    • Once the flap is lifted, gently pull the ribbon cable out of the connector. Pull straight out and avoid side-to-side motion to ensure the cable and its contacts aren’t damaged.
  5. Lenovo 100e Chromebook Display Removal, disconnect battery connection to motherboard: 手順 5、 2の画像 1 Lenovo 100e Chromebook Display Removal, disconnect battery connection to motherboard: 手順 5、 2の画像 2
    • Use a plastic tool such as the opening tool or opening pick to carefully disconnect the battery from the motherboard
    • This part is kind of difficult be careful not to break this cord pushing it out.
  6. Lenovo 100e Chromebook Display Removal, Remove screen bezel: 手順 6、 3の画像 1 Lenovo 100e Chromebook Display Removal, Remove screen bezel: 手順 6、 3の画像 2 Lenovo 100e Chromebook Display Removal, Remove screen bezel: 手順 6、 3の画像 3
    • flip device over to remove the screen bezel.
    • Using a spudger, go along the edge of the screen and pop the connections between the cover and the back side out.
    • Insert the spudger into the gap between the hinges and pull up to detach the connections.
    • Set aside once removed
  7. Lenovo 100e Chromebook Display Removal, Remove display: 手順 7、 2の画像 1 Lenovo 100e Chromebook Display Removal, Remove display: 手順 7、 2の画像 2
    • Remove 4 screws using the Phillips #00 screwdriver bit.
    • Carefully pull the screen back onto the lower assembly.
  8. Lenovo 100e Chromebook Display Removal, Disconnect Display cord: 手順 8、 2の画像 1 Lenovo 100e Chromebook Display Removal, Disconnect Display cord: 手順 8、 2の画像 2
    • Peel back the protective tape over the display cable using the spudger. Gently lift the black bar latch holding the cable in place, until the cable becomes loose. Pull the cable free and remove the display.
終わりに
作成者
1人の作成者と共同作成されました。
Emilio Acuna-reyes
メンバー登録日: 04/22/24
157 ポイント
1ガイドが承認済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 13
今までの合計 139
