はじめに
Issues with your Wi-Fi/Bluetooth Card? No problem, it can be easily replaced!
必要な工具と部品
Turn the laptop over.
Remove the 10 phillips head screws and keep them organized.
Using a Spudger, carefully separate the cover from the corner. It snaps back in, so make sure to not break any clips.
Take out the cover and set it aside.
To disconnect the battery, carefully pull the black connector in a parallel direction to the laptop.
Carefully disconnect the antenna cables from the card with an upward movement.
Remove the Phillips head screw.
Pull from the motherboard in a parallel direction.
To reassemble your device, follow these instructions in reverse order. Congrats! You've upgraded your Wi-Fi Card.
