メインコンテンツにスキップ
Leica Z2X Lens Cover Replacement
必要な工具と部品
  1. Leica Z2X Lens Cover Replacement, Remove the Bottom Screws: 手順 1、 1の画像 1
    • Carefully unscrew the four Phillips #0 screws on the bottom of the camera.
    • There is a screw located inside of the tripod hole (large circle.) Make sure the screw is removed from there too!
  2. Leica Z2X Lens Cover Replacement, Open the Back Door: 手順 2、 1の画像 1
    • Open the back door on the camera by pushing down on the door latch.
  3. Leica Z2X Lens Cover Replacement, Remove the Bottom Plate: 手順 3、 1の画像 1
    • Apply pressure to the bottom plate and it will pop off.
    • From here, you can replace the bottom plate, or continue on to further steps.
  4. Leica Z2X Lens Cover Replacement, Lens Motor: 手順 4、 1の画像 1
    • Having opened the camera and removed the bottom plate, unscrew the five screws marked in the picture.
    • The screw marked in blue is a tiny bit harder to find because it's in a crevice. Don't miss it!
  5. Leica Z2X Lens Cover Replacement: 手順 5、 1の画像 1
    • Apply pressure until the piece you unscrewed in the last step pops off.
  6. Leica Z2X Lens Cover Replacement: 手順 6、 1の画像 1
    • Unscrew the four screws on the back of this piece to the lower-left corner of the lens.
  7. Leica Z2X Lens Cover Replacement: 手順 7、 1の画像 1
    • Removing the lens motor cover, you should be left with these four pieces.
  8. Leica Z2X Lens Cover Replacement: 手順 8、 1の画像 1
    • Located underneath these four pieces is the lens motor.
  9. Leica Z2X Lens Cover Replacement: 手順 9、 1の画像 1
    • Now that you've removed the bottom plate, you can pull apart the front and back covers.
    • Start with the front cover and, by applying pressure (perhaps a lot of pressure), snap off the front cover.
  10. Leica Z2X Lens Cover Replacement: 手順 10、 1の画像 1
    • Next, the back cover.
    • Apply pressure to remove the back plate.
    • Be careful of the buttons on the top of the camera falling off, they are small parts and CAN get lost easily.
    • The best way to remove the back is to stick your thumbs on either side of the battery socket and separate from there.
  11. Leica Z2X Lens Cover Replacement: 手順 11、 1の画像 1
    • You should now have removed the front and back plates.
  12. Leica Z2X Lens Cover Replacement: 手順 12、 1の画像 1
    • Remove the four screws holding on the front panel surrounding the lens.
  13. Leica Z2X Lens Cover Replacement: 手順 13、 1の画像 1
    • Remove the three gears under the panel you removed in the last step and the lens motor should be able to be removed.
  14. Leica Z2X Lens Cover Replacement, Lens Cover: 手順 14、 1の画像 1
    • Now that the lens motor has been removed, you can apply pressure to the back of the lens and push it out.
    • From here, locate the three screws near the front of the lens.
    • Unscrew these three screws.
  15. Leica Z2X Lens Cover Replacement: 手順 15、 1の画像 1
    • From here, you can pull out the small disk containing the lens cover.
    • Unscrew the four screws on the back and pull the two pieces of the disk apart.
  16. Leica Z2X Lens Cover Replacement: 手順 16、 1の画像 1
    • From here, you can replace any broken parts in the lens cover.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Kenny
メンバー登録日: 04/10/11
57 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 18-19, Garner Spring 2011 Cal Poly, Team 18-19, Garner Spring 2011人のメンバー
CPSU-GARNER-S11S18G19
4 メンバー
13のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 16
今までの合計 2,905
