メインコンテンツにスキップ
Leather Stitching Replacement
必要な工具と部品
  1. Leather Stitching Replacement, Leather Stitching: 手順 1、 3の画像 1 Leather Stitching Replacement, Leather Stitching: 手順 1、 3の画像 2 Leather Stitching Replacement, Leather Stitching: 手順 1、 3の画像 3
    • Using scissors, cut the thread at the seams.
  2. Leather Stitching Replacement: 手順 2、 3の画像 1 Leather Stitching Replacement: 手順 2、 3の画像 2 Leather Stitching Replacement: 手順 2、 3の画像 3
    • Take the thread out with your fingers.
  3. Leather Stitching Replacement: 手順 3、 2の画像 1 Leather Stitching Replacement: 手順 3、 2の画像 2
    • The new piece of leather thread should be three times the length of the stitch plus the length of the two needles.
    • Cut the thread.
    • Push one end of the thread through the eye of the needle.
    • Do the same for the other end, with the second needle.
  4. Leather Stitching Replacement: 手順 4、 3の画像 1 Leather Stitching Replacement: 手順 4、 3の画像 2 Leather Stitching Replacement: 手順 4、 3の画像 3
    • To tie the thread, bring the open end of the thread to the tip of the needle.
    • Push the needle all the way through the thread.
    • Pull the thread to secure the knot at the top.
    • You do not want a short end because the knot will come loose.
  5. Leather Stitching Replacement: 手順 5、 3の画像 1 Leather Stitching Replacement: 手順 5、 3の画像 2 Leather Stitching Replacement: 手順 5、 3の画像 3
    • Line up the first hole on both pieces.
    • Push one needle all the way through.
    • Pull till the length of the thread is equal on each side.
  6. Leather Stitching Replacement: 手順 6、 3の画像 1 Leather Stitching Replacement: 手順 6、 3の画像 2 Leather Stitching Replacement: 手順 6、 3の画像 3
    • You should have a needle on the right side of the leather and one on the left.
    • Push the right side needle through the second hole.
    • Push the left side need through the same hole.
    • Tug each side to tighten the stitch.
    • After tugging, you will end up having a needle on the right side and left side.
  7. Leather Stitching Replacement: 手順 7、 1の画像 1
    • With each hole, make sure both needles go through to the other side and are pulled together to tighten the stitch.
    • Continue this pattern until the end.
  8. Leather Stitching Replacement: 手順 8、 3の画像 1 Leather Stitching Replacement: 手順 8、 3の画像 2 Leather Stitching Replacement: 手順 8、 3の画像 3
    • To finish the stitch, we are going to push the needle into the second-to-last hole.
    • It should not pass through both pieces, only the one piece.
    • Do this for both sides.
  9. Leather Stitching Replacement: 手順 9、 3の画像 1 Leather Stitching Replacement: 手順 9、 3の画像 2 Leather Stitching Replacement: 手順 9、 3の画像 3
    • Tie the finishing knot by crossing the threads and pushing the needle through the made hole.
    • Pull to tighten and repeat once.
  10. Leather Stitching Replacement: 手順 10、 3の画像 1 Leather Stitching Replacement: 手順 10、 3の画像 2 Leather Stitching Replacement: 手順 10、 3の画像 3
    • Use the scissors to cut off the excess thread.
ゴール
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Mimansa (Momo) Tyagi
メンバー登録日: 08/27/20
384 ポイント
1ガイドが承認済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 13
過去 30 日: 56
今までの合計 1,420
