メインコンテンツにスキップ
Leapfrog My Own Leaptop Speaker Replacement Guide
必要な工具と部品
  1. Leapfrog My Own Leaptop Speaker Replacement Guide, Battery: 手順 1、 1の画像 1
    • Flip over device so that back portion of the device is facing you.
  2. Leapfrog My Own Leaptop Speaker Replacement Guide: 手順 2、 1の画像 1
    • Unscrew the one 10mm screw that holds the battery cover in place with a a PH1 phillips head screwdriver.
    • Please note that the screw cannot be removed as it is attached to the battery cover.
  3. Leapfrog My Own Leaptop Speaker Replacement Guide: 手順 3、 2の画像 1 Leapfrog My Own Leaptop Speaker Replacement Guide: 手順 3、 2の画像 2
    • Carefully pry the batteries out with a plastic opening tool prying from the non spring side.
    • Remove the three AA batteries.
    • Note the direction of the batteries for when reassembling.
  4. Leapfrog My Own Leaptop Speaker Replacement Guide, Speaker: 手順 4、 1の画像 1
    • Remove the eleven 10mm screws from the back of the device with a a PH1 phillips head screwdriver.
  5. Leapfrog My Own Leaptop Speaker Replacement Guide: 手順 5、 1の画像 1
    • Carefully remove back of the device.
    • Make sure not to rip the wires when lifting the cover off.
  6. Leapfrog My Own Leaptop Speaker Replacement Guide: 手順 6、 2の画像 1 Leapfrog My Own Leaptop Speaker Replacement Guide: 手順 6、 2の画像 2
    • Unscrew the two 7.5 mm screws to the left and right of the speaker with a PH1 phillips head screwdriver.
    • Remove the cover and place to the side.
  7. Leapfrog My Own Leaptop Speaker Replacement Guide: 手順 7、 2の画像 1 Leapfrog My Own Leaptop Speaker Replacement Guide: 手順 7、 2の画像 2
    • Once the cover is removed, gently lift up the speaker making sure not to rip or break the wires.
    • If you are disassembling the device to clean the speaker, clean it at this point with a soft, lightly dampened cloth.
    • Gently turn the speaker over and carefully desolder the white and yellow wires from the speaker.
終わりに
Any issues that cannot be resolved with any portion of this wiki please contact Leapfrog Customer Serivce
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Jonathan Fitzer
メンバー登録日: 02/10/16
584 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 14-6, Lacy Spring 2016 USF Tampa, Team 14-6, Lacy Spring 2016人のメンバー
USFT-LACY-S16S14G6
4 メンバー
6のガイドは作成済み
5 件のコメント
Thanks for this very useful instruction. Where can I buy a replacement speaker?
-Don
Don La - 返信
I agree, but I also second the question...where can I buy a replacement speaker?
Jimmy Liang - 返信
Where could I purchase a replacement speaker?
Zuzi - 返信
Where could I buy the replacement speaker in Malaysia?
stanley.met - 返信
Where can I buy replacement speaker in Malaysia? Appreciate yr reply
ribenabona - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 12
過去 30 日: 37
今までの合計 6,715
