メインコンテンツにスキップ
Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide
必要な工具と部品
  1. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide, Battery: 手順 1、 1の画像 1
    • Flip over device so that back portion of the device is facing you.
  2. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 手順 2、 1の画像 1
    • Unscrew the one 10mm screw that holds the battery cover in place with a a PH1 phillips head screwdriver.
    • Please note that the screw cannot be removed as it is attached to the battery cover.
  3. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 手順 3、 2の画像 1 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 手順 3、 2の画像 2
    • Carefully pry the batteries out with a plastic opening tool prying from the non spring side.
    • Remove the three AA batteries.
    • Note the direction of the batteries for when reassembling.
  4. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide, Keyboard Buttons: 手順 4、 1の画像 1
    • Remove the eleven 10mm screws from the back of the device with a a PH1 phillips head screwdriver.
  5. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 手順 5、 1の画像 1
    • Carefully remove back of the device.
    • Make sure not to rip the wires when lifting the cover off.
  6. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 手順 6、 2の画像 1 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 手順 6、 2の画像 2
    • Remove the three 10mm screws from the upper left hand corner white plastic piece with a PH1 phillips head screwdriver.
    • Unscrew the five 4mm screws from the plastic membrane with a PH1 phillips head screwdriver.
  7. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 手順 7、 1の画像 1
    • Remove the white plastic piece and place it to the side.
  8. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 手順 8、 3の画像 1 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 手順 8、 3の画像 2 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 手順 8、 3の画像 3
    • Gently grab the membrane and peal it upwards.
    • Carefully remove the membrane and set it to the side.
    • From this step you can also clean the membrane of any residue with a lightly dampened paper towel.
    • Ensure that the membrane is completely dry before reassembly.
  9. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 手順 9、 2の画像 1 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 手順 9、 2の画像 2
    • Gently lift and remove the foam piece
  10. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 手順 10、 3の画像 1 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 手順 10、 3の画像 2 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: 手順 10、 3の画像 3
    この手順で使用する道具:
    購入する
    • From here, each button is able to be removed for cleaning or replacement.
    • Using a tweezers or needle nose pliers, remove the necessary pieces from the device.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Jonathan Fitzer
メンバー登録日: 02/10/16
584 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 14-6, Lacy Spring 2016 USF Tampa, Team 14-6, Lacy Spring 2016人のメンバー
USFT-LACY-S16S14G6
4 メンバー
6のガイドは作成済み
6 件のコメント
Very useful. but where to get a new membrane? please help
Alina Timchenko - 返信
Didn't work. I'll buy a new toy.
victoria_nglover19 - 返信
Is the screen on this suppose to light up?
stewartmelinda41 - 返信
I was wondering if the screen is suppose to light up because the one I have doesnt
thank you very much
Njabulo Mbele - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 12
過去 30 日: 51
今までの合計 5,268
