メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Leapfrog LeapPad 3 Display Assembly Replacement
必要な工具と部品
ビデオの概要
  1. Leapfrog LeapPad 3 Display Assembly Replacement, Battery: 手順 1、 3の画像 1 Leapfrog LeapPad 3 Display Assembly Replacement, Battery: 手順 1、 3の画像 2 Leapfrog LeapPad 3 Display Assembly Replacement, Battery: 手順 1、 3の画像 3
    この手順で使用する道具:
    Anti-Static Wrist Strap
    $7.95
    • Before taking apart your device, ensure that it is turned off and that your anti-static wrist strap is secured to a ground.
    • Remove the six 10.0 mm Phillips #0 screws from the outer case and remove the cover with your hands.
    • You will not need to pry the case off.
  2. Leapfrog LeapPad 3 Display Assembly Replacement: 手順 2、 3の画像 1 Leapfrog LeapPad 3 Display Assembly Replacement: 手順 2、 3の画像 2 Leapfrog LeapPad 3 Display Assembly Replacement: 手順 2、 3の画像 3
    • Unplug the battery from the motherboard with your hands.
    • The battery sits to the right of the motherboard.
  3. Leapfrog LeapPad 3 Display Assembly Replacement: 手順 3、 2の画像 1 Leapfrog LeapPad 3 Display Assembly Replacement: 手順 3、 2の画像 2
    • Pry the battery gently off of the plastic platform with an opening tool.
    • Do not to puncture the battery, as the material inside can be dangerous.
  4. Leapfrog LeapPad 3 Display Assembly Replacement, Speaker: 手順 4、 2の画像 1 Leapfrog LeapPad 3 Display Assembly Replacement, Speaker: 手順 4、 2の画像 2
    • Disconnect the audio cord from the motherboard using a plastic opening tool.
    • When re-plugging this cord be sure it is flush with the slot, otherwise the speaker and directional pad will malfunction.
    • Use caution when unplugging, and re-plugging the ribbon cord as they are fragile.
  5. Leapfrog LeapPad 3 Display Assembly Replacement: 手順 5、 3の画像 1 Leapfrog LeapPad 3 Display Assembly Replacement: 手順 5、 3の画像 2 Leapfrog LeapPad 3 Display Assembly Replacement: 手順 5、 3の画像 3
    • Unscrew the five 6.0 mm phillips head screws from the board containing the audio jack and directional pad.
  6. Leapfrog LeapPad 3 Display Assembly Replacement: 手順 6、 3の画像 1 Leapfrog LeapPad 3 Display Assembly Replacement: 手順 6、 3の画像 2 Leapfrog LeapPad 3 Display Assembly Replacement: 手順 6、 3の画像 3
    • Unscrew the three 6.5 mm phillips head screws holding down the speaker to the right of the audio jack.
    • Remove the board and speaker from the device.
  7. Leapfrog LeapPad 3 Display Assembly Replacement, Motherboard: 手順 7、 2の画像 1 Leapfrog LeapPad 3 Display Assembly Replacement, Motherboard: 手順 7、 2の画像 2
    • Unplug the front facing camera cord with an opening tool to free the top of the motherboard.
  8. Leapfrog LeapPad 3 Display Assembly Replacement: 手順 8、 3の画像 1 Leapfrog LeapPad 3 Display Assembly Replacement: 手順 8、 3の画像 2 Leapfrog LeapPad 3 Display Assembly Replacement: 手順 8、 3の画像 3
    • Remove the three 6 mm phillips head screws holding the motherboard to the display assembly.
  9. Leapfrog LeapPad 3 Display Assembly Replacement: 手順 9、 3の画像 1 Leapfrog LeapPad 3 Display Assembly Replacement: 手順 9、 3の画像 2 Leapfrog LeapPad 3 Display Assembly Replacement: 手順 9、 3の画像 3
    • Carefully lift the motherboard out of the case, exposing the last remaining cord on the underside of the motherboard.
    • Disconnect the gold display assembly cord with an opening tool to fully disconnect the motherboard.
    • The device was rotated 180 degrees in order to unplug the display assembly cord.
  10. Leapfrog LeapPad 3 Display Assembly Replacement, Display Assembly: 手順 10、 2の画像 1 Leapfrog LeapPad 3 Display Assembly Replacement, Display Assembly: 手順 10、 2の画像 2
    • Unscrew the eight 6.5mm Phillips #0 screws from the plastic casing.
  11. Leapfrog LeapPad 3 Display Assembly Replacement: 手順 11、 3の画像 1 Leapfrog LeapPad 3 Display Assembly Replacement: 手順 11、 3の画像 2 Leapfrog LeapPad 3 Display Assembly Replacement: 手順 11、 3の画像 3
    • Remove the covering with your hands to allow full view of the display assembly.
  12. Leapfrog LeapPad 3 Display Assembly Replacement: 手順 12、 3の画像 1 Leapfrog LeapPad 3 Display Assembly Replacement: 手順 12、 3の画像 2 Leapfrog LeapPad 3 Display Assembly Replacement: 手順 12、 3の画像 3
    • Remove the display assembly from the black rubber sleeve carefully.
    • There is a specific orientation for the rubber sleeve so take note of its position.
終わりに
5 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Matt Irvine
メンバー登録日: 02/04/16
952 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team 16-2, Blackwell Winter 2016 USF Tampa, Team 16-2, Blackwell Winter 2016人のメンバー
USFT-BLACKWELL-W16S16G2
3 メンバー
12のガイドは作成済み
4件のガイドコメント
Everything worked ok but unit now will not go to home page. after I replaced the display. They tell you necessary tools but never tell you where or how to use the wrist grounding strap.
Dave Alan - 返信 共有
Bonjour, j’ai bien réussi à accéder à l’écran,
Ma question:
Oû peut-on se procurer un écran neuf SVP?
Gregory Commarmond - 返信 共有
Pouvez vous m'indiquer où trouver un écran de remplacement ?
Merci d'avance
Domi Luky - 返信 共有
OK, Visiblement ce tuto ne sert plus à rien car il est Impossible de trouver le display de remplacement!!
Domi Luky - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 25
今までの合計 1,489
