はじめに
To replace the battery you will need a replacement. Once you have the battery, following this guide will lead you to a fully functioning device.
必要な工具と部品
この手順で使用する道具:Anti-Static Wrist Strap$7.95
Before taking apart your device, ensure that it is turned off and that your anti-static wrist strap is secured to a ground.
Remove the six 10.0 mm Phillips #0 screws from the outer case and remove the cover with your hands.
3 の人々がこのガイドを完成させました。
1件のガイドコメント
where can i purchase a battery, i have googled and come up with nothing.
martinez2503 - 返信 共有
