メインコンテンツにスキップ
LeapPad Ultra Battery Replacement
必要な工具と部品
  1. LeapPad Ultra Battery Replacement, Battery: 手順 1、 1の画像 1
    • Remove the barcode covering the two screws on the lower back of the Leap Pad.
  2. LeapPad Ultra Battery Replacement: 手順 2、 1の画像 1
    • Remove the two 5 mm screws that were covered by the sticker.
  3. LeapPad Ultra Battery Replacement: 手順 3、 1の画像 1
    • Using a plastic opening tool, pry off the outer protective child proof casing, starting from the bottom.
    A long flat-tip screwdriver can be used to push the tab out from the other side as they hook inwards towards the center. You can see the locations in the step 4 photo near the edges.
    Eric Tong - 返信
  4. LeapPad Ultra Battery Replacement: 手順 4、 1の画像 1
    • Remove the 7 mm screw to the right of the cartridge dock, two 8 mm screws in the top left, and the nine 8 mm screws holding the the green shell.
    My device had the 7mm screw to the right of the cartridge slot and the 2 to the left of the cartridge slot were also 7mm.
    the other 9 were indeed 8mm,
    Mike.
    Mike Gilmour - 返信
  5. LeapPad Ultra Battery Replacement: 手順 5、 1の画像 1
    • Remove the hard plastic casing, exposing the motherboard and battery.
  6. LeapPad Ultra Battery Replacement: 手順 6、 2の画像 1 LeapPad Ultra Battery Replacement: 手順 6、 2の画像 2
    • Disconnect the battery using tweezers or your fingernails.
    • The battery is glued down, if available put some isopropyl alcohol around the edges of the battery to soften the glue.
    • Gently pry of the battery lose using a spudger or another thin prying tool.
    • Be careful, damaging/puncturing the battery may cause an explosion.
    This was extremely helpful, and easy to do!! Thank you so much! You saved the day!
    Bailey Condon-Salmon - 返信
終わりに
To reassemble the device, follow these instructions in reverse order.
7 の人々がこのガイドを完成させました。
作成者
10人の作成者と共同で作成されました。
Ryan Arredondo
メンバー登録日: 08/31/15
246 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 4-99, Meier Fall 2015 USF Tampa, Team 4-99, Meier Fall 2015人のメンバー
USFT-MEIER-F15S4G99
4 メンバー
10のガイドは作成済み
4 件のコメント
Hi Ryan, will removing the battery delete any of the downloaded apps and saved files?
Michael - 返信
I’m not Ryan, but I just did this process and the apps and files are all still there.
Kivi Shapiro - 返信
What is a spudger and where do I get a battery
P Mac - 返信
Hello, if anyone still has this leappad Ultra and wanted to purchase a new battery. I have found a retail store https://batteryclerk.com/ The price is reasonable, and I'm just waiting for the batteries to arrive.
Mike Silva - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 10
過去 30 日: 33
今までの合計 16,106
