はじめに
Use this guide in order to capture the essence of replacing your back camera, enabling you to capture the world!
必要な工具と部品
Before disassembling your LeapPad, ensure your device is shut off.
Push outward on the plastic side panels to remove and reveal battery.
The panels should detach fully from the main device.
Remove the following screws securing the back cover to the main device:
Two 10.0 mm Phillips screws
Four 4.0 mm Phillips screws
Three 3.0 mm Phillips screws
もう少しです!
終わりに
