メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
LeapFrog LeapPad Ultra Repair Speaker Replacement
必要な工具と部品
  1. LeapFrog LeapPad Ultra Repair Speaker Replacement, Battery: 手順 1、 1の画像 1
    • Remove the barcode covering the two screws on the lower back of the Leap Pad.
  2. LeapFrog LeapPad Ultra Repair Speaker Replacement: 手順 2、 1の画像 1
    • Remove the two 5 mm screws that were covered by the sticker.
  3. LeapFrog LeapPad Ultra Repair Speaker Replacement: 手順 3、 1の画像 1
    • Using a plastic opening tool, pry off the outer protective child proof casing, starting from the bottom.
  4. LeapFrog LeapPad Ultra Repair Speaker Replacement: 手順 4、 1の画像 1
    • Remove the 7 mm screw to the right of the cartridge dock, two 8 mm screws in the top left, and the nine 8 mm screws holding the the green shell.
  5. LeapFrog LeapPad Ultra Repair Speaker Replacement: 手順 5、 1の画像 1
    • Remove the hard plastic casing, exposing the motherboard and battery.
  6. LeapFrog LeapPad Ultra Repair Speaker Replacement: 手順 6、 2の画像 1 LeapFrog LeapPad Ultra Repair Speaker Replacement: 手順 6、 2の画像 2
    この手順で使用する道具:
    • Disconnect the battery using tweezers or your fingernails.
    • The battery is glued down, if available put some isopropyl alcohol around the edges of the battery to soften the glue.
    • Gently pry of the battery lose using a spudger or another thin prying tool.
    • Be careful, damaging/puncturing the battery may cause an explosion.
  7. LeapFrog LeapPad Ultra Repair Speaker Replacement, Speaker: 手順 7、 1の画像 1
    • Find the screws on the bottom of the device holding down the button and speakers board.
  8. LeapFrog LeapPad Ultra Repair Speaker Replacement: 手順 8、 2の画像 1 LeapFrog LeapPad Ultra Repair Speaker Replacement: 手順 8、 2の画像 2
    • There should be a plastic covering over the speaker, carefully pull on the opposite side from the plastic clip holding it in place.
    • Excessive force can break the plastic clip, only use enough for to remove it gently
  9. LeapFrog LeapPad Ultra Repair Speaker Replacement: 手順 9、 2の画像 1 LeapFrog LeapPad Ultra Repair Speaker Replacement: 手順 9、 2の画像 2
    • Lift the button and speaker board, and turn it over, revealing the other side of the board.
  10. LeapFrog LeapPad Ultra Repair Speaker Replacement: 手順 10、 2の画像 1 LeapFrog LeapPad Ultra Repair Speaker Replacement: 手順 10、 2の画像 2
    • Find the ribbon cable connection and with a small plastic tool flip the plastic holding it down up.
    • You can now safely remove the ribbon cable by gently pulling it out of the slot.
    • Trying to remove the cable with brute force will damage the cable.
終わりに
作成者
3人の作成者と共同で作成されました。
Carlos Ortiz
メンバー登録日: 08/24/15
225 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 4-99, Meier Fall 2015 USF Tampa, Team 4-99, Meier Fall 2015人のメンバー
USFT-MEIER-F15S4G99
4 メンバー
10のガイドは作成済み
1件のガイドコメント
Where can i buy a replacement speaker at to do this?
anthonydesiato2002 - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 21
今までの合計 1,241
