メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
LeapFrog LeapPad Ultra Repair Back Camera Replacement
必要な工具と部品
  1. LeapFrog LeapPad Ultra Repair Back Camera Replacement, Battery: 手順 1、 1の画像 1
    • Remove the barcode covering the two screws on the lower back of the Leap Pad.
  2. LeapFrog LeapPad Ultra Repair Back Camera Replacement: 手順 2、 1の画像 1
    • Remove the two 5 mm screws that were covered by the sticker.
  3. LeapFrog LeapPad Ultra Repair Back Camera Replacement: 手順 3、 1の画像 1
    • Using a plastic opening tool, pry off the outer protective child proof casing, starting from the bottom.
  4. LeapFrog LeapPad Ultra Repair Back Camera Replacement: 手順 4、 1の画像 1
    • Remove the 7 mm screw to the right of the cartridge dock, two 8 mm screws in the top left, and the nine 8 mm screws holding the the green shell.
  5. LeapFrog LeapPad Ultra Repair Back Camera Replacement: 手順 5、 1の画像 1
    • Remove the hard plastic casing, exposing the motherboard and battery.
  6. LeapFrog LeapPad Ultra Repair Back Camera Replacement: 手順 6、 2の画像 1 LeapFrog LeapPad Ultra Repair Back Camera Replacement: 手順 6、 2の画像 2
    この手順で使用する道具:
    • Disconnect the battery using tweezers or your fingernails.
    • The battery is glued down, if available put some isopropyl alcohol around the edges of the battery to soften the glue.
    • Gently pry of the battery lose using a spudger or another thin prying tool.
    • Be careful, damaging/puncturing the battery may cause an explosion.
  7. LeapFrog LeapPad Ultra Repair Back Camera Replacement, Motherboard: 手順 7、 3の画像 1 LeapFrog LeapPad Ultra Repair Back Camera Replacement, Motherboard: 手順 7、 3の画像 2 LeapFrog LeapPad Ultra Repair Back Camera Replacement, Motherboard: 手順 7、 3の画像 3
    • Disconnect the three wires that will be visible on top of the motherboard. The wires need to be disconnected by pulling them up vertically.
  8. LeapFrog LeapPad Ultra Repair Back Camera Replacement: 手順 8、 1の画像 1
    • Unscrew the five screws holding the motherboard into the housing.
  9. LeapFrog LeapPad Ultra Repair Back Camera Replacement: 手順 9、 3の画像 1 LeapFrog LeapPad Ultra Repair Back Camera Replacement: 手順 9、 3の画像 2 LeapFrog LeapPad Ultra Repair Back Camera Replacement: 手順 9、 3の画像 3
    • Lift the motherboard up exposing the fourth and final wire. Once you lift up the motherboard you will need to pull down on the wire to disconnect.
  10. LeapFrog LeapPad Ultra Repair Back Camera Replacement: 手順 10、 1の画像 1
    • Remove and replace motherboard.
  11. LeapFrog LeapPad Ultra Repair Back Camera Replacement, Back Camera: 手順 11、 1の画像 1
    この手順で使用する道具:
    • Disconnect the ribbon cable attached to the camera itself by using tweezers.
  12. LeapFrog LeapPad Ultra Repair Back Camera Replacement: 手順 12、 1の画像 1
    • On the reverse side of the motherboard, there will be two clips that will need to be pushed together to remove.
終わりに
作成者
5人の作成者と共同で作成されました。
Rocky Hirsch
メンバー登録日: 08/27/15
902 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 4-99, Meier Fall 2015 USF Tampa, Team 4-99, Meier Fall 2015人のメンバー
USFT-MEIER-F15S4G99
4 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 13
今までの合計 628
