はじめに
To replace the battery is a mild task to get to and can take up to 15 minutes to complete. A far warning, patience is key because the device itself is difficult to open . The only tools that will be needed will be a screwdriver and some tweezers .
必要な工具と部品
Flip over the Pad to its back side to begin the removal of the back panel.
Begin by removing the blue rim along the edge of the device. It runs along the green silicone lining.
Begin with the removal of the battery from its place.
Flip the black switch that is connecting the battery to the motherboard.
Then pull gently and should disconnect.
