メインコンテンツにスキップ
LeapFrog LeapPad Ultimate Camera Replacement
必要な工具と部品
  1. LeapFrog LeapPad Ultimate Camera Replacement, Back Panel: 手順 1、 2の画像 1 LeapFrog LeapPad Ultimate Camera Replacement, Back Panel: 手順 1、 2の画像 2
    • Flip over the Pad to its back side to begin the removal of the back panel.
    • Begin by removing the blue rim along the edge of the device. It runs along the green silicone lining.
    • This is very difficult to remove , so do be patient. To help remove the seal, both a metal spudger and plastic opening tool may be used.
    • Remove the pen from its place before starting to avoid tangling.
  2. LeapFrog LeapPad Ultimate Camera Replacement: 手順 2、 2の画像 1 LeapFrog LeapPad Ultimate Camera Replacement: 手順 2、 2の画像 2
    • Once the blue rim is removed, the 12 screws will be visible.
    • Use the Phillips #1 screwdriver to unscrew all 12 screws.
  3. LeapFrog LeapPad Ultimate Camera Replacement, Camera: 手順 3、 1の画像 1
    • Remove the 3 screws on each corner of the motherboard
  4. LeapFrog LeapPad Ultimate Camera Replacement: 手順 4、 3の画像 1 LeapFrog LeapPad Ultimate Camera Replacement: 手順 4、 3の画像 2 LeapFrog LeapPad Ultimate Camera Replacement: 手順 4、 3の画像 3
    • Remove the ribbon on the bottom of the motherboard and the ribbon on the left side of the motherboard.
    • There will be a small black switch on top of the ribbons that you must flip to take them out.
  5. LeapFrog LeapPad Ultimate Camera Replacement: 手順 5、 1の画像 1
    • Remove the 3-pin connector on the top left side of the motherboard.
  6. LeapFrog LeapPad Ultimate Camera Replacement: 手順 6、 2の画像 1 LeapFrog LeapPad Ultimate Camera Replacement: 手順 6、 2の画像 2
    • Flip the motherboard to its back side and pinch the 2 green hooks to remove the camera cover
  7. LeapFrog LeapPad Ultimate Camera Replacement: 手順 7、 1の画像 1
    • Remove the ribbon connecting the camera to the motherboard. You have now taken out the camera and can replace it with a new one.
終わりに
作成者
2人の作成者と共同で作成されました。
Nabil Mustafa
メンバー登録日: 09/21/18
223 ポイント
2のガイドは作成済み
チーム
University of North Texas, Team S1-G13, Riccardelli Fall 2018 University of North Texas, Team S1-G13, Riccardelli Fall 2018人のメンバー
UNT-RICCARDELLI-F18S1G13
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 228
