メインコンテンツにスキップ
LeapFrog LeapPad Ultimate Battery Replacement
必要な工具と部品
  1. LeapFrog LeapPad Ultimate Battery Replacement, Battery: 手順 1、 2の画像 1 LeapFrog LeapPad Ultimate Battery Replacement, Battery: 手順 1、 2の画像 2
    • Flip over the Pad to its back side to begin the removal of the back panel.
    • Remove the blue rim along the edge of the device. It runs along the green silicone lining.
    • This is very difficult to remove , so do be patient. To help remove the seal both the metal and the plastic spudgers may be used.
    • Remove the pen from its place before starting to avoid tangling.
  2. LeapFrog LeapPad Ultimate Battery Replacement: 手順 2、 1の画像 1
    • Once the blue rim is removed, the 12 screws will be visible.
    • Use a Phillips #1 screwdriver to unscrew all 12 screws.
  3. LeapFrog LeapPad Ultimate Battery Replacement: 手順 3、 1の画像 1
    • Remove the back panel of the device exposing the internal components of the device.
    • Once the internal components are exposed locate the point which connects the battery to the motherboard.
  4. LeapFrog LeapPad Ultimate Battery Replacement: 手順 4、 3の画像 1 LeapFrog LeapPad Ultimate Battery Replacement: 手順 4、 3の画像 2 LeapFrog LeapPad Ultimate Battery Replacement: 手順 4、 3の画像 3
    この手順で使用する道具:
    購入する
    • The point connecting the battery and motherboard is made up of three wires, red, white, and black.
    • The plastic portion on the motherboard's end will have a small notch on top. Pull the notch in the direction towards the battery with the curved tweezers. This will disconnect the wires from the motherboard.
  5. LeapFrog LeapPad Ultimate Battery Replacement: 手順 5、 2の画像 1 LeapFrog LeapPad Ultimate Battery Replacement: 手順 5、 2の画像 2
    • Carefully remove the battery from the LeapPad, use the plastic spudger to gain leverage, if needed.
終わりに
3 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Fernando Lozano-Garcia
メンバー登録日: 09/21/18
356 ポイント
2のガイドは作成済み
チーム
University of North Texas, Team S1-G13, Riccardelli Fall 2018 University of North Texas, Team S1-G13, Riccardelli Fall 2018人のメンバー
UNT-RICCARDELLI-F18S1G13
4 メンバー
12のガイドは作成済み
4 件のコメント
Does anyone know where I can order a new battery? I can’t find the MH46844 Battery anywhere.
corinnemorrissey - 返信
Did you find this battery..?
mark phillips -
I am also struggling to track down one of these batteries. Can anyone provide any advice on where to look for one?
Neil Paynter - 返信
we disconnected the battery and reconnected and now the leap pad just turns on to the leap start up screen and straight off again continuously any tips on how to stop this?
kayla_dicko - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 75
今までの合計 6,121
