必要な工具と部品
Remove the 4 screws of the speaker using a torque screwdriver for M4 screws.
Pull the speaker out of the concrete casing to make the connections accessible.
To disconnect the speaker, pull each of the 2 cables down by their connector, making small left-to-right movements.
Remove the speaker from the concrete casing.
As the concrete casing and the electronic basket are separated, lift the concrete casing to separate it from the basket.
The underside of the concrete shell has a different texture from the others, so be careful to position it correctly.
Connect the speaker as in step 3. Be careful to place the speaker connectors on the side of the concrete shell that includes a notch.
To reassemble your device, follow the instructions in reverse order.
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
