メインコンテンツにスキップ
Le Pan II Charging Port Replacement
必要な工具と部品
  1. Le Pan II Charging Port Replacement, Screen: 手順 1、 2の画像 1 Le Pan II Charging Port Replacement, Screen: 手順 1、 2の画像 2
    • Insert metal spudger between front and back panel to pry apart.
    • Continue to pry while moving the metal spudger along the crevice to completely separate two panels.
    • Avoid using metal when opening devices, as it can damage or crack the screen.
  2. Le Pan II Charging Port Replacement: 手順 2、 2の画像 1 Le Pan II Charging Port Replacement: 手順 2、 2の画像 2
    • Use the plastic opening tool to disconnect the flat ribbon cable from the motherboard connector.
    • Disconnect the flat ribbon by gently pulling it out from its connecting port.
  3. Le Pan II Charging Port Replacement: 手順 3、 2の画像 1 Le Pan II Charging Port Replacement: 手順 3、 2の画像 2
    • Use the plastic opening tool to disconnect the display cable from its motherboard connector.
    • Disconnect the display cable by gently pulling it out from its connecting port.
  4. Le Pan II Charging Port Replacement: 手順 4、 1の画像 1
    • Remove grey metal backing from screen.
  5. Le Pan II Charging Port Replacement: 手順 5、 1の画像 1
    • Flip the tablet so the screen is facing upward, and use the metal spudger to pry apart the screen from the side pieces.
  6. Le Pan II Charging Port Replacement: 手順 6、 1の画像 1
    • Lift and carefully remove the LCD display from the front cover.
  7. Le Pan II Charging Port Replacement, Charging Port: 手順 7、 1の画像 1
    • Use the Phillips 00 screwdriver head to unscrew the screws to the motherboard.
    • Reminder: There should be 8 (3.5 mm) screws to the motherboard.
  8. Le Pan II Charging Port Replacement: 手順 8、 1の画像 1
    • Use the Phillips 00 screwdriver head to unscrew the screws to the fan.
    • Reminder: There should be 4 (1mm) screws to the fan.
  9. Le Pan II Charging Port Replacement: 手順 9、 1の画像 1
    • Use the metal spudger to pry off the charging port from the motherboard.
終わりに
作成者
1人の作成者と共同作成されました。
Kelly Moniz
メンバー登録日: 10/20/16
513 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team 6-3, Martin Fall 2016 UMass Dartmouth, Team 6-3, Martin Fall 2016人のメンバー
UMASSD-MARTIN-F16S6G3
3 メンバー
10のガイドは作成済み
コメント 1 件
I have had no luck getting in touch with anyone in the customer service department.I have left several messages but have not heard from anyone yet. I just need to know how I can get a charge port for my daughters tablet. She had it 6 months before the charge port went out.
tashiarmarshall - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 1,230
