メインコンテンツにスキップ
Laser Lens Cleaning
必要な工具と部品
  1. Laser Lens Cleaning, Top Panel: 手順 1、 2の画像 1 Laser Lens Cleaning, Top Panel: 手順 1、 2の画像 2
    • Remove four 7.5 mm Phillips screws on the both sides (2 on each side).
    • Remove five 7.5 mm Phillips screws on the back of the player.
    When i put in a dvd the dvd player want open
    I have to unplug it and plug it back in, so it
    will open. If I don't put a dvd in it opens and'
    closes fine. What's causing this ?
    John Bailey - 返信
  2. Laser Lens Cleaning: 手順 2、 2の画像 1 Laser Lens Cleaning: 手順 2、 2の画像 2
    • Lift the top panel from the back and remove. It should come off without being forced. There is a lip near the front so you many need to slide the top panel back slightly to remove it.
  3. Laser Lens Cleaning, Laser Lens Cleaning: 手順 3、 2の画像 1 Laser Lens Cleaning, Laser Lens Cleaning: 手順 3、 2の画像 2
    • Locate the lens on the disc drive.
    • Make sure that there is no dust on or near the player and area you are working on. Dust can get on the lens and scratch it while you are cleaning. It is very important that the lens is not damaged because the lens is used to read the discs.
    • Dip one end of a cotton swab in rubbing alcohol.
    • Lightly dab the swab on the lens. Be very gentle.
    • Let the lens dry before replacing the top plate of the DVD player.
終わりに
12 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Nathan Klammer
メンバー登録日: 10/06/11
461 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 21-20, Maness Fall 2011 Cal Poly, Team 21-20, Maness Fall 2011人のメンバー
CPSU-MANESS-F11S21G20
4 メンバー
7のガイドは作成済み
3 件のコメント
This item was not appropriate, thank you for trying.
bigd734 - 返信
Works on Samsung's box(home theater), thank you!
CarlBraun - 返信
It worked on my cheap player. This unit is on 24/7. The dust in the house is heavy and smokers so the fix is cheap and I picked up a few things. Thanks
Seeker - 返信
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 67
過去 30 日: 343
今までの合計 48,405
