メインコンテンツにスキップ
Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement
必要な工具と部品
  1. Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement, Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone: 手順 1、 2の画像 1 Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement, Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone: 手順 1、 2の画像 2
    • Switch off the grinder's breaker box before performing any maintenance on the machine.
  2. Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: 手順 2、 2の画像 1 Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: 手順 2、 2の画像 2
    • Lift the yellow guard up to unlock the grindstone access panel.
  3. Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: 手順 3、 2の画像 1 Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: 手順 3、 2の画像 2
    • Pull the access panel outward to expose the grindstone.
  4. Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: 手順 4、 2の画像 1 Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: 手順 4、 2の画像 2
    • Remove the twelve bolts securing the grindstone using a ratchet with a 5/16 Hex bit.
  5. Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: 手順 5、 2の画像 1 Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: 手順 5、 2の画像 2
    • Gently remove the steel hub from the grindstone spindle.
  6. Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: 手順 6、 2の画像 1 Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: 手順 6、 2の画像 2
    • Carefully remove the grindstone itself from the spindle, making sure to support it from the top and inner ring.
    • Mind your fingers! The grindstone is quite heavy and can cause injury if it is mishandled or dropped.
  7. Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: 手順 7、 2の画像 1 Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: 手順 7、 2の画像 2
    • Softly sand the hub with 600-grit sandpaper or a wire brush to remove any surface rust.
  8. Landis Universal Cylindrical Grinder (3U4D5D-17 ) Grindstone Replacement: 手順 8、 1の画像 1
    • Although not mandatory, now would be a good time to scrape out any debris that has built up on the inside of the guard.
終わりに
To reassemble your device, follow these instructions in reverse order starting from step 6.
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Andrew Shotwell
メンバー登録日: 02/23/16
136 ポイント
1ガイドが承認済み
チーム
Texas Tech, Team 22-3, Rauch Spring 2016 Texas Tech, Team 22-3, Rauch Spring 2016人のメンバー
TTU-RAUCH-S16S22G3
3 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 50
今までの合計 893
