メインコンテンツにスキップ
Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement
必要な工具と部品
  1. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement, Hose: 手順 1、 1の画像 1
    • Place the hair dryer on a sturdy surface with its backside facing up.
    • Using a Phillips #1 screwdriver, remove the six 12.7 mm screws from the back of the hair dryer.
  2. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 手順 2、 1の画像 1
    • Open the hair dryer, and place the front cover to the side.
  3. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 手順 3、 2の画像 1 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 手順 3、 2の画像 2
    • Disconnect the clear tube from the hose cuff.
  4. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 手順 4、 2の画像 1 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 手順 4、 2の画像 2
    • Untwist the hose cuff off the fan opening.
  5. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 手順 5、 2の画像 1 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 手順 5、 2の画像 2
    • Pull the hose through the hose cuff until it reaches the top of the inner rim.
  6. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 手順 6、 1の画像 1
    • Place and twist the hose cuff onto the fan opening.
  7. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 手順 7、 3の画像 1 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 手順 7、 3の画像 2 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 手順 7、 3の画像 3
    • Slide the hose through the clear tube.
    • Slide the clear tube until it meets the rim of the hose cuff.
  8. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 手順 8、 1の画像 1
    • Place the hair dryer's front cover on top of the back cover, leaving a finger's width space for the next step.
  9. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 手順 9、 2の画像 1 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 手順 9、 2の画像 2
    • Align the wire cover to the grooves of the left and right sides of the hair dryer.
    • Pull the cord through the wire opening.
    • Lightly press on the wire cover to secure its placement.
    • Push the front cover down to close the hair dryer.
  10. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 手順 10、 2の画像 1 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 手順 10、 2の画像 2
    • Carefully flip the hair dryer on its backside.
    • Place a screw in each opening, and screw them until secure.
  11. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: 手順 11、 1の画像 1
    • Gently pull the hose to ensure it is secure.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Paige Guillory
メンバー登録日: 09/21/21
235 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team 1-10, Boettger Spring 2022 University of North Texas, Team 1-10, Boettger Spring 2022人のメンバー
UNT-BOETTGER-S22S1G10
1 メンバー
1のガイドは作成済み
コメント 1 件
Please provide resource for purchasing a replacement bonnet for the Laila Ali LADR5604
Joyce Johnson - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 21
今までの合計 798
