必要な工具と部品
LG Washer, OE error code message. Washing cycle doesn't finish, water doesn't drain. CLOGGED DRAIN PUMP FILTER.
Related video: https://www.facebook.com/100004990830507...
To assist in opening the filter cover, we can use a blunt knife or a flat screwdriver.
The pump is located in the bottom tray, we need to turn the filter cap a couple of turns, WITHOUT UNSCREWING IT COMPLETELY, this way we are slowly opening and closing to drain the water slowly without flooding the room.
This is a home made tool that I also use to check the pump's propeller without having to remove it.
This is a PVC tube, 16 mm by 20 cm (tube used for electrical installations). I used a saw and a small file to make four slits on one end so I can grip the propeller and confirm if it rotates or not.
The tube is inserted to grip the propeller, then it needs to be rotated to confirm if there is any issue or resistance when turning (damaged motor).
ある他の人がこのガイドを完成しました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
